timmoore46
Using the camera ... help !
Sat Apr 30, 2016 4:03 pm
I've got the camera working but where does it store the photos it takes ?
Maybe I'm using the wrong command ?
any thoughts very welcome !
:oops: :cry:
Tim
B.Goode
Re: Using the camera ... help !
Sat Apr 30, 2016 4:27 pm
Crystal ball is very fuzzy this afternoon....
Give us some little hints to let us help you.
What camera?
What Operating System?
What command are you using?
timmoore46
Sat Apr 30, 2016 4:45 pm
Raspbian 26th Feb 2016 edition
from the Terminal
The image flashes up for a few seconds and thats it...
Not obvious how to take a photo that I can look at again ! *LOL*
I though its a 'no brainer' that most folk want to be able to see their photos, guess I'm having an 'off' day !
Many thanks for responding,
:P
Tim
timmoore46
Sat Apr 30, 2016 4:47 pm
Oh... it is the latest 8 MP IR version.
DirkS
Sat Apr 30, 2016 4:52 pm
It should be in the directory from where you issued the command.
Most likely your home directory.
BTW: did you update / upgrade before using the camera?
B.Goode
Sat Apr 30, 2016 5:10 pm
+1 to the suggestions made by @DirkS.
Check for the presence of the file:
(that's letter 'ell' the first two times, but One in the filename.)
B.Goode
Sat Apr 30, 2016 5:42 pm
There are some Comments in the RPF blog post that suggest that maybe updated software is required for the new cameras. https://www.raspberrypi.org/blog/new-8- ... d-sale-25/
(But I might have misunderstood, and I don't have a new camera to check against.)
There is a forum thread dedicated to the 8mp cameras: viewtopic.php?f=43&t=145815
timmoore46
Sat Apr 30, 2016 6:46 pm
got a Rpi Model B 1GHz working, added the camera did the up grades etc and tried to take a photo:-
and got this back....
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC ETC ETC
Please check for firmware updates...
the wiFi built in one just worked once and gave up after I crashed Raspbian..
I'll get some upto date raspbian micro card tomorrow and see if that helps....
No sure which bit is giving all the grief.....
Any thoughts always welcome....
Tim
timmoore46
Sun May 01, 2016 2:06 pm
On the 18th of March a new version of Raspian was on offer, so I downloaded it and took all my micro SD cards and put it on them....
That completely fixed the problem !
First I did:-
sudo apt-get update
sudo apt-get upgrade
sudo raspi-config
with that I maxed available space also enabled the camera.
re-booted
and lo everything worked including the camera !
got a photo stored in the home directory !
I'll go round my other Pi's and see how they cope with the 18th March version of Raspian !I did find two knacked micro SD cards and that caused 99% of the problems ! (I think)
Thanks to all who offered support !!!
:P :P :P
Tim
Return to “Camera board”
