I have 3 devices: Rasberry Pi2, Rasberry Pi3 and Rasberry Pi-Zero.
Ras3 has Ubuntu installed, the other 2 standard Rasbian.
I'm trying to connect all of them to HDMI switch but I'm having lots of issues. Fist switch was simple 3-in 1-out.
When I'm connecting the OS goes to 640-480 mode which looks terrible (to big).
I thought initially it is a switch problem so I bought more expensive and sophisticated one. Same thing happens. Now not only resolution goes to 640x480 but also no signal is found. I have to unplug and plug back the HDMI cable to the switch to make the signal go to the monitor. This 3nd switch was highly rated on Amazon although I haven't seen anybody using it with RasPi.
Any suggestions ? I'm thinking about hard coding the screen resolutions into the OS but I'm not sure if this is possible and if this is the best route to go. I do not understand why when booting up the device does not recognize it is connected to HD monitor, although when connected directly it all works fine.
Any suggestions ?
ARTHUR
