Hello all!
About five months ago I setup my raspberry pi 2 with Jessie. Changed the username and removed the "pi" account. It is also setup for remote desktop connection so I can control it from my main Windows PC. Yesterday I rebooted it after the web browser kept crashing when I went to Google.com.
Upon reboot it went to a black and white login screen that showed rp2-default in the upper left, the ability to shutdown/restart in the upper right, and also the ability to select default XSession/LXDE/or OpenBox in the upper right. If I enter my username:pw it goes black for a while then immediately comes back to the login screen. I have tried root:[no pw], root:root, pi:raspbian to no avail.
If I ctrl-alt-f1 then it displays:
"Raspbian GNU/Linux 8 rp2-default tty1
rp2-default login: pi (automatic login)
Authentication failure"
and I cannot use the command prompt nor press ctr-c to cancel out. I tried remote desktop and it just shows a black screen with no login window.
Has anyone encountered this before? If so, were you able to fix it?
Thanks so much.
