shedicus
cheap mouse that actually works off the bat
Sun Apr 24, 2016 9:57 pm
hi im new to the pi community and thought as a newbie id contribute something, i got my first pi today which as we speak is running off a pc power-supply for testing purposes. i tried a number of mice and none worked they just flashed now and again. well i found that the poundshop mouse works straight away no issues so anyone in need of a mouse to get going with use the one from poundland etc.
rpdom
Re: cheap mouse that actually works off the bat
Mon Apr 25, 2016 7:16 pm
I bought a USB mouse from a pound shop last week. It didn't work. Upon investigation (couldn't be bothered to go out of my way to take it back), I found that the mouse was fine, but the USB cable was so thin that two out of the four wires had broken.
tpylkko
Mon Apr 25, 2016 8:01 pm
I have microsoft basic optical mouse v2, which is really simple but it has worked on RPi models A+. B+ 2 and 3.
PiGraham
Mon Apr 25, 2016 8:10 pm
I have used several mice with various Pis and they all just worked. Something like:
Logitech, Microsoft, Packard Bell, Poundland, others.
I have a Cherry USB keyboard that doesn't work directly connected to A+ or Zero. That works fine on a powered hub.
Look up raspberry Pi hardware compatibility list.
zardoz66
Tue Apr 26, 2016 4:28 am
Most every basic mouse I have ever used has worked fine.
Zardoz
Raspberry Pi 3 | Raspbian Jessie | 32GB Samsung EVO+ | D-Link 7 port USB HUB | Sabrent CRW-EXT 6-Slot Card Reader | 64GB USB Storage. Other RPi's - 2x RPi1b, 1x Rpi1b+ 1x Rpi2b, 2x Rpi3b
Join us on IRC #raspberrypi at https://webchat.freenode.net/
FTrevorGowen
Wed Apr 27, 2016 6:50 pm
Over the years I've checked out quite a few mice** - FWIW some basic info. (with links to pictures) is here:
https://www.cpmspectrepi.uk/raspberry_p ... Dlist.html
Trev.
** Including at least one "Pounsstore" device.
