we are restoring old cutting machine at work and unfortunately it has only USB port, not ethernet. Therefore with each cutting plan our designer has to leave office, go across the factory and plug in the loaded flashdrive, cut the "products" and go back to office for another.
I'm wondering if there is a possibility for any Raspberry Pi model to act as USB flash drive with ability to be "loaded" over the network? Better said Raspberry Pi would act as a shared drive to network computers and in the same time as flashdrive to the embedded computer in the cutting machine.
I've tried to find the solution across many forums, but it seems to be quite unique and maybe impossible solution. I assume I'm looking for board with OTG support, therefore only Pi Zero is in the game, but there is no network interface and only one of the USB ports can data connection
Any help in this matter would be greatly appreciated
Jakoob
