izzycm
Car Dash Replacement Project
Fri Apr 22, 2016 11:00 am
Hello all!
I am working on a Car Dash Replacement project for an 84 Camaro Z28. I'll try and update as I go through and get stuff completed with the steps that I took to get it done...
Goals for the Project:
Create a Complete Dash Replacement that can do the following:
  • Multiple Displays with the ability to Dim back-lighting
  • GPS Navigation
  • GPS Speedometer
  • Tachometer
  • Accelerometer to measure G-Force
    Multiple Temperature Sensors
  • Lambda Sensor
  • Backup Camera
Hardware for Project:
This is a list of the components that I have thus far to start the project:
  • 2x Raspberry Pi 3B + NOOBS MicroSD Cards
  • Microstack Accelerometer unit (3 axis accelerometer)
  • Microstack GPS
  • Microstack Baseboard
  • 2x 1024x600 touch Screen LCD Displays
  • Raspberry Pi Camera Module
  • Pi Camera Extension adapter for HDMI (up to 15ft.)
  • Pi-EZ Connect Terminal Block Breakout Hat
  • Right Angle Female Header
Software Attempting to use for project:
  • Raspbian 4.1 (Jessie)(Wheezy)
  • Or
  • Windows 10 IoT Core
izzycm
Re: Car Dash Replacement Project
I Swapped one of the Raspberry Pi 3's for a Pi 2 because I was having issues getting the GPS to work properly...
I have installed the following:
Installed Raspbian (Jessie)
TightVNCServer
sudo apt-get install tightvncserver
and added it to auto start with the Pi
sudo nano /etc/rc.local
and added these lines to the bottom of the file
# Start tightvncserver
su - pi -c '/usr/bin/tightvncserver :1`
Set Static IP address
sudo nano /etc/dhcpcd.conf
and added the following lines (Replace ## with the correct IP Schema you use)
static ip_address=192.168.##.##
static routers=192.168.##.##
static domain_name_servers=192.168.##.##
Update the system
sudo apt-get update
sudo apt-get upgrade
Prep system for GPS and Accelerometer
sudo raspi-config
Under Advanced Options > A6-SPI and A7-I2C Enable and set to load by default. A8-Serial, Disable. Reboot Pi
izzycm
Installing GPS and Accelerometer
izzycm
Fri Apr 22, 2016 11:01 am
(Reserved for Updates)
CarnageTR
Sat Apr 23, 2016 10:31 am
Why are u using 2 pies?
izzycm
Sat Apr 23, 2016 6:30 pm
With having the 2 displays I figured I would have 1 Pi drive each of the screens.
JoshMilner
Thu Jun 16, 2016 6:55 pm
I'd love to see it installed in the car!
Hagar
Mon Jun 20, 2016 9:45 am
Do you have your progress displayed on a website or blog? Love to see how its going
izzycm
Sat Aug 27, 2016 1:05 pm
Sorry for the delay in posting, it has been quite a hectic summer....
Anyways here are the updates!
I started with making the dash out of Foam Core board and 2 part epoxy.
https://pix.sfly.com/Vcb9vr
After I had that made I fit in the 2x 7" Touch screens and Tach.
https://pix.sfly.com/OT-emH
Then I had to adjust the orientation of the screens by 90 degrees to make everything look right.https://pix.sfly.com/dXnHrC
Then after fitting it into the car I realized... I forgot to add turn signal indicators.... :lol: so I added them. https://pix.sfly.com/Zpk21q
Now I'm working on hooking them up to a Car power supply from http://mausberry-circuits.myshopify.com ... y-switches so it will auto shutdown the Pi unit when I turn off the Ignition.
I also have ordered an Arduino Nano for interfacing to the Left Pi, so that it can read the analog readings from my Wide-band 02 sensor that ill be adding. I am also looking into having a Mass airflow sensor interface with it also...
I'll hopefully have these setup in the next few weeks... along with more pics :)
izzycm
Thu Sep 01, 2016 11:38 am
I received my Arduino Nanos yesterday and was able to get them to talk to the pi via USB cable...
sudo apt-get install arduino
More info to come
