wmkhizer
Raspberry Pi - Data logging
Thu Apr 21, 2016 4:48 pm
Hi there, im kinda new to raspberry pi.
Can someone share some tips & advice on how to make a data logging.
I'm using Raspberry pi 2 model B, Jessie.
Hope all the experts out there can help the newbies here :)
experix
Re: Raspberry Pi - Data logging
Fri Apr 22, 2016 12:47 am
"data logging" is a huge category. Nobody can tell you how to do "data logging". Start with a defined problem, and you can get lots of hints about what to use and how to use it.
wmkhizer
Fri Apr 22, 2016 7:47 am
oh sorry for that..
im currently working on a project using a GPS (ublox neo 6m).
I've connected the GPS to GPIO ports and it work okay. i wanted to collect & save all the data that it receives.
so i was just wondering how to do that..
davidcoton
Fri Apr 22, 2016 8:49 am
wmkhizer wrote:oh sorry for that..
How much data each time, and how often?
Signature retired
Sat Apr 23, 2016 10:40 pm
Are you going to decode the NMEA sentences or simply store those for later processing?
Do you want to use a flat file, a comma separated variables file (which you can load in LibreOffice Calc or Excel), or a database of some description?
This is a doctor free zone.
wmkhizer
Tue Apr 26, 2016 5:08 pm
DougieLawson wrote:Are you going to decode the NMEA sentences or simply store those for later processing?
Sorry for the late reply, i just want to simply store it for later processing.
A comma separated variables would be nice. easily to put in excel n etc..
i'm not quite sure. Every few seconds? How would you recommend?
davidcoton
Tue Apr 26, 2016 5:13 pm
wmkhizer wrote:How much data each time, and how often?
Are you tracking a walker or a rocket? What precision do you need (that is, what distance error can you tolerate before updating)?
You need to think through these basics (and probably several more) to define your requirements before trying to specify a solution.
Signature retired
liudr
Tue Apr 26, 2016 6:38 pm
I recommend Python as the programming language. You need to install pyserial library though. You can open serial port and just dump whatever you read to a file, flush the file periodically to prevent loss.
Install the library:
sudo pip3 install pyserial
Then find some sample code of serial port communication. I assume you have your GPS hooked up to the AMA0 serial port on GPIO pins, correct?
Arduino data loggers, user interface, printed circuit board designer since 2009, RPI 3B 2B 2B Zero Jessie, assembly/C/C++/java/python programmer since the 80's
