broshet
Installing Scrypt by Gem
Tue Apr 19, 2016 8:12 am
I have trouble with Gem and Scrypt module installation on my RPI1 :
 sudo gem install scrypt
I can't remove msse gcc option (for Intel processor). When I modify the script, the install command download server version ... Can you help me ?
Installing scrypt 2.0.2 with native extensions
Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
    /usr/bin/ruby2.1 -rubygems /var/lib/gems/2.1.0/gems/rake-11.1.2/bin/rake RUBYARCHDIR=/tmp/bundler20160419-25810-7pj53fscrypt-2.0.2/extensions/arm-linux/2.1.0/scrypt-2.0.2 RUBYLIBDIR=/tmp/bundler20160419-25810-7pj53fscrypt-2.0.2/extensions/arm-linux/2.1.0/scrypt-2.0.2
mkdir -p arm-linux
/usr/bin/ruby2.1 -I/var/lib/gems/2.1.0/gems/ffi-compiler-0.1.3/lib/ffi-compiler/fake_ffi /var/lib/gems/2.1.0/gems/ffi-compiler-0.1.3/lib/ffi-compiler/exporter.rb ../../lib/scrypt/scrypt_ext.rb ./scrypt_ext.h
gcc -fexceptions -O -fno-omit-frame-pointer -fno-strict-aliasing -Wall -msse -msse2 -fPIC  -o arm-linux/crypto_scrypt-sse.o -c ./crypto_scrypt-sse.c
gcc: error: unrecognized command line option â-msseâ
gcc: error: unrecognized command line option â-msse2â
rake aborted!
Command failed with status (1): [gcc -fexceptions -O -fno-omit-frame-pointe...]
/var/lib/gems/2.1.0/gems/ffi-compiler-0.1.3/lib/ffi-compiler/compile_task.rb:114:in `block (2 levels) in define_task!'
Tasks: TOP => default => arm-linux/libscrypt_ext.so => arm-linux/crypto_scrypt-sse.o
(See full trace by running task with --trace)
rake failed, exit code 1
Gem files will remain installed in /tmp/bundler20160419-25810-7pj53fscrypt-2.0.2/gems/scrypt-2.0.2 for inspection.
Results logged to /tmp/bundler20160419-25810-7pj53fscrypt-2.0.2/extensions/arm-linux/2.1.0/scrypt-2.0.2/gem_make.out
Return to “C/C++”
