I have tested every single possible configuration, but still I can't get it to work. When I issue any "gpio command" from the console, everything works just fine. Set mode or Write both return the expected results.
But when the commands are issued via crontab (root's) @reboot, nothing works and I can't even set the pin mode.
I have a fresh install of Raspbian, installed git-core and then built from wiringPi folder. Dependencies seem met given the working commands from cli, but still I can't figure out where it's failing at boot.
A simple "@reboot gpio mode 0 out; gpio write 0 1" in the crontab file doesn't turn on the led.
Thanks in advance for any pointer
