xslide
Disable sleep mode
Sun Apr 17, 2016 11:10 am
I use my Raspberry Pi 2 (Raspbian) as a kiosk with fullscreen webpage.
My problem is, that Raspberry turn off display each 15 minutes. I try to disable sleep mode, but this is not working.
I try:
1)ALT+F2 gksu leafpad /etc/kbd/config
2) set BLANK_TIME=0 a POWERDOWN_TIME=0.
3) save
4)ALT+F2 gksu leafpad /etc/xdg/lxsession/LXDE-pi/autostart
5) add lines
@xset s noblank
@xset s off
@xset -dpms
This method not working for me. Do you have any idea where is a problem? Thank you
JimmyN
Re: Disable sleep mode
Sun Apr 17, 2016 1:14 pm
Method #1 and #2 only disable blanking if you're logged into console, they don't work when running the desktop.
Method #4~#5 should work but you're using the old location.
Add it to the users autostart file at "~/.config/lxsession/LXDE-pi/autostart", rather than adding it to the global autostart file at "/etc/xdg/...".
xslide
Sun Apr 24, 2016 10:33 am
Hi, I try your method but i faild.
What I must type to terminal for setting this?
I try sudo nano ~/.config/lxsession/LXDE-pi/autostart and gksu leafpad ~/.config/lxsession/LXDE-pi/autostart but not working.
Can you help me how to edit this file?
Thank you very much!
Rive
Sun Apr 24, 2016 12:44 pm
xslide wrote:Hi, I try your method but i faild.
Here is how to disable blanking and monitor standby/off in pi3 (should work with pi2 I suspect)
Open terminal
Open:
sudo nano /boot/config.txt
Add:
# power down monitor when lockscreen enabled
hdmi_blanking=1
add:
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
Save 'Cntrl +X', then 'Y', then 'Enter'
reboot
sudo reboot
DNPNWO
JimmyN
Sun Apr 24, 2016 1:28 pm
xslide wrote: I try sudo nano ~/.config/lxsession/LXDE-pi/autostart and gksu leafpad ~/.config/lxsession/LXDE-pi/autostart but not working.
If you used "sudo" you changed the ownership of the "pi" users autostart file to "root". You might want to change that back so it belongs to "pi" again. Using "sudo" to edit files that are supposed to belong to "pi" can cause permission problems.
sudo chown pi:pi /home/pi/.config/lxsession/LXDE-pi/autostart
Rive
Sun Apr 24, 2016 2:14 pm
That is neat, but unnecessary for this file.
I modified this file myself with sudo (to disable blanking), and I have no issues. It can be "viewed" and executed by "anyone". In any event, the Owner is still "pi".
DNPNWO
calde315
Wed Jun 08, 2016 1:10 pm
I'm having similar issues. I have my pi running constantly while hooked up via HDMI to my TV. After a couple days of not using it, the output of the pi appears to be not there. No key presses, mouse moves do anything. But it's still able to ssh just fine. The only way I'm able to get picture back on the screen is a reboot. It's like it's sleeping, but unlike a traditional PC, a keystroke or shake of the mouse doesn't awaken it.
I have a raspberry pi B+ or 2, I'm hoping these fixes above work for these Pi's. I know someone said it should work for the 2, but can anyone confirm it works for the B+ as well?
sparrow_tech
Mon Oct 03, 2016 1:11 pm
I'm having a similar problem trying to disable sleep mode. Rive I noticed that in your screenshot the autostart file has been edited to have the last line as:
@setx dpms 0 0 7200
What does this do differently from the above suggestions? Any other suggestions to disable sleep mode?
