iAlle
Raspberry Pi3 shutdown itself
Sat Apr 16, 2016 1:00 pm
Hi guys, i just got my raspberry pi3 and entering in this new world, I'm a noob, so please help me :D
I connected the raspberry to my tv with HDMI cable, and all is working fine, but after 2/3 minutes it shutdown by itself, and on TV appear "No Signal" message. So i have disconnect power supply, i reconnect power and it start.
It seems is working fine at start, normally booting (i think). I tried to install raspabian and at 11/12% of installation, boom, shutdown and "no signal", so i tried to format sd and mount on it retropie 3.7 (that was part of my project for an arcade cabinet). It boots normally, and when i reach configuration (pad settings) it shutdown again.
Help please, and sorry for my bad English :P
UPDATE: When i'm in terminal the raspberry is working fine and doesn't shutdown.
Rive
Re: Raspberry Pi3 shutdown itself
Sat Apr 16, 2016 2:14 pm
My guess would be power supply issue or overheat issue
DNPNWO
iAlle
Sat Apr 16, 2016 2:31 pm
after a few try that's my guess to, but how is possible?
i got it from an amazon supplier with the starter pack, that gave me the switching adapter +5.1V - 2.5A - i've mounted heat sinker too.
Rive
Sat Apr 16, 2016 3:05 pm
iAlle wrote:after a few try that's my guess to, but how is possible?
Verify that the power supply is correct (does the red light blink at all, or is it continuous and steady? Blinking or unsteady indicates a power supply issue), otherwise, get a better heatsink, or try a fan.
For example:
DNPNWO
