Kennnny12
startup problems
Wed Apr 13, 2016 4:47 pm
My raspberry pi wan't startup anymore like you can see in the video ( https://www.youtube.com/watch?v=niFnpfb30Bo) . I only get e black screen with an white dot who is pinking in the left corner. Does somebody know what the problem is and how i can solve it ?
thanks !
Greetings
TrapdoorSmoke
Re: startup problems
Wed Apr 13, 2016 9:23 pm
Hello From My Own experience this is a common problem on Raspbian.
1.Make sure when your done with the Pi you shutdown completely do not pull power till its done shuting down. Not doing This Could Cause SD Corruption.
2. Maybe you Unistalled LXDE
So What you can do is reinstall raspbian to the SD card, follow this tutorial https://www.raspberrypi.org/documentati ... ng-images/
And on when you start up the Pi wait until the icons and menu comes up.(It could take I while when booting be patient.)
Reply If this doesn't work.
