philspitler
Permisions
Wed Apr 13, 2016 7:03 am
I finally had my SMB share working today so that my PiZero could read files from my OSX Server.
But something has stopped working.
Now when i type sudo mount - a I get a permissions error.
sudo mount -a -v
mount.cifs kernel mount options: ip=192.168.1.45,unc=\\192.168.1.45\Two_Terror,iocharset=utf8,uid=1000,gid=1000,user=philspitler,pass=********
mount error(13): Permission denied
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
It was working perfectly earlier and I haven't being doing anything that would screw up the permissions.
I am a total noobie with Linux so I don't really know where to start looking.
Any ideas?
Cheers.
MarkHaysHarris777
Re: Permisions
Wed Apr 13, 2016 7:11 am
Your security options are probably wrong.
Use the -v switch to see if you can get some more information from the mount command... also check your log files in /var/log
What have you changed lately?
marcus
:ugeek:
philspitler
Re: Permisions
Wed Apr 13, 2016 4:57 pm
Thanks Marcus, the output in my original post was with the -v and it didn't really give any clues to me.
I looked in the logs but there are so many files again no read flags.
The things I have been working on were getting an SMB share to mount on the PiZero by editing the /etc/fstab file.
I think I must have screwed up my fstab file is I noticed it was missing a few lines from the top;
proc            /proc           proc    defaults          0       0
/dev/mmcblk0p6  /boot           vfat    defaults          0       2
/dev/mmcblk0p7  /               ext4    defaults,noatime  0       1
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
I added these back in and it seems to be fine now.
Any chance you could help me understand what these lines are doing?
Thanks again.
Phil
JimmyN
Re: Permisions
Wed Apr 13, 2016 5:30 pm
Thanks again.
Phil
It's mounting the 6th partition on the SDCard as "/boot" (vfat filesystem).
It's mounting the 7th partition on the SCDard as "/" (ext4 filesystem).
It's creating the /proc filesystem, which is virtual (it doesn't contain "real" files, it's for runtime system information).
