My situation:
I have a RPi 3 that came with the version of NOOBS released just before the 2016-03-18 one.
I know that, therefore, Wifi can't work if I don't install the 2016-03-18 one.
My problem:
When I plug an ethernet cable between my router and the RPi3 to do the download... I don't get internet either (whereas I do have wifi from the same router)
As a result
I feel like I am a bit trapped...
One detail, though
Once (and only once), for a reason I do not know, I started getting access to internet through the ethernet cable, and did the get update etc... But when I tried the wifi, it did not work, and now if put the cable back it does not work anymore.
My question
I can see only 2 things - either I have a hardware issue somewhere, or there is something tricky with my config. Could you recommand a set of steps to, at least, look into this issue with the cable connection? I could understand a problem with Wifi, but not with the cable.
