You've probably worked this one out already, but i happen to have a DHT22 and Raspberry at the side of me that ive been using for humidity only readings,.. so thought id have a play and put something together for the temps. most of this is copy/paste from previous projects and im self taught from reading forums so theres probably much better code available.. columns, rows, screen size is off.
this code does work, at the moment changes a tkinter label from "off" red to "on" green when temp is equal or greater than designated setting.
import Tkinter as tk
from Tkinter import *
import threading
import Adafruit_DHT
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
sensor = Adafruit_DHT.DHT22
pin = 17
root = tk.Tk()
root.geometry("1200x720")
canvas = Canvas(width=1280, height=720, bg='black')
canvas.grid(rowspan=5, columnspan=8, sticky='W,E,N,S')
i_fan_slow = 18
# Input Fan Slow Temp
def is_minus_temp():
global i_fan_slow
if i_s_m["text"] == "-":
i_fan_slow -= 1
ifan_s.config(text=i_fan_slow)
root.update_idletasks()
def is_plus_temp():
global i_fan_slow
if i_s_p["text"] == "+":
i_fan_slow += 1
# Maths
def maths():
while 1:
humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
temp = ("%02d" % temperature)
if temperature is not None:
c_temp.config(text=temp)
if temperature >= i_fan_slow:
gpio.config(text="On", bg='green')
if temperature < i_fan_slow:
gpio.config(text="Off", bg='red')
time.sleep(1)
i_s_m = tk.Button(root, text="-", width=1, font=('aharoni', 30, 'bold'), command=is_minus_temp, bg='black', fg='white')
i_s_p = tk.Button(root, text="+", width=1, font=('aharoni', 30, 'bold'), command=is_plus_temp, bg='black', fg='white')
ifan_s = Label(root, text=i_fan_slow, width=4, font=('aharoni', 32, 'bold'), bg='black', fg='white')
ifan_s.grid(padx=5, pady=10, row=2, column=1, sticky='N')
i_s_m.grid(row=2, column=1, padx=15, pady=2, sticky="N,W")
i_s_p.grid(row=2, column=1, padx=15, pady=2, sticky="N,E")
c_temp = Label(root, text=" ", width=4, font=('aharoni', 32, 'bold'), bg='black', fg='white')
c_temp.grid(padx=5, pady=10, row=2, column=3, sticky='N')
gpio = Label(root, text="Off", width=4, font=('aharoni', 32, 'bold'), bg='red', fg='white')
gpio.grid(padx=5, pady=10, row=3, column=1, sticky='N')
t11 = threading.Thread(target=maths)
t11.daemon = True
t11.start()
root.mainloop()
