Rive
SOLVED-Raspbian Jessie: failed to start Load Kernel Modules?
Sat Apr 09, 2016 4:17 pm
Keep getting this "Unit systemd-modules-load.service entered failed state."
I want to troubleshoot, and resolve this (my goal is to remove the fail message at boot).
Any ideas? Thanks. I though it might have been I2C (which is disabled in raspi-config), but now, i just dunno.
Here is the boot scroll message:
Failed] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
6.080707] systemd[1]: failed to start Load Kernel Modules.
6.097303] systemd[1]: Unit systemd-modules-load.service entered failed state.
pi@raspberrypi:~ $ systemctl status systemd-modules-load.service
● systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static)
   Active: failed (Result: exit-code) since Sat 2016-04-09 12:01:28 EDT; 13min ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 85 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 85 (code=exited, status=1/FAILURE)
DNPNWO
Re: Raspbian Jessie: failed to start Load Kernel Modules?
Sun Apr 10, 2016 1:31 pm
Have you changed something in /etc/modules-load.d/*.conf? because it looks like you may have introduced a syntax error or are trying to load a non-existent module.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
DirkS
Sun Apr 10, 2016 1:43 pm
Try
sudo systemctl status systemd-modules-load.service
You should get some more info (last messages logged)
Rive
Sun Apr 10, 2016 4:02 pm
DougieLawson wrote:Have you changed something in /etc/modules-load.d/*.conf? because it looks like you may have introduced a syntax error or are trying to load a non-existent module.
sudo nano /etc/modules-load.d/*.conf
/etc/modules-load.d/cups-filters.conf
# Parallel printer driver modules loading for cups
# LOAD_LP_MODULE was 'yes' in /etc/default/cups
lp
ppdev
parport_pc
/etc/modules-load.d/modules.conf
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
i2c-dev
DirkS wrote: Try
pi@raspberrypi:~ $ sudo systemctl status systemd-modules-load.service
   Active: failed (Result: exit-code) since Sat 2016-04-09 23:31:27 EDT; 12h ago
  Process: 86 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 86 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
DNPNWO
Rive
Sun Apr 10, 2016 4:39 pm
Thanks. Resolved.
Looks like it was caused by cups/hplip/hp-setup:
sudo apt-get install hplip
sudo hp-setup -i
In any event, through trial and error, I stopped the boot fail error by commenting all out like so:
#lp
#ppdev
#parport_pc
I have a wireless network HP printer, I am going to test to make sure it still works, If so, I will mark this thread as [Solved].
DNPNWO
michigeo
Re: SOLVED-Raspbian Jessie: failed to start Load Kernel Modu
Tue Oct 18, 2016 9:30 pm
I have the same problem with cups, it causes the kernel to fail. I also have a CANON network printer that with cups does not print! My question is how you solved the problem, i did not understand.
thanks in advance
DNPNWO
Tue Oct 18, 2016 9:51 pm
michigeo wrote:I have the same problem with cups, it causes the kernel to fail. I also have a CANON network printer that with cups does not print! My question is how you solved the problem, i did not understand.
thanks in advance
He went into:
and commented out (#) all the following lines like so:
#lp
#ppdev
#parport_pc
apbonn
Thu May 18, 2017 3:16 pm
i ve got the same problem, but inside of /etc/modules-load.d/cups-filters.conf is nothing i could comment out?
How to solve this now?
Fri May 19, 2017 4:11 pm
apbonn wrote:i ve got the same problem, but inside of /etc/modules-load.d/cups-filters.conf is nothing i could comment out?
Just remove that file.
Then reboot and see what journalctl -xe tells you.
MQTT Evangelist
mrpraline
Sun May 21, 2017 10:52 am
This problem is caused by the cups-filters package. This will install /etc/modules-load.d/cups-filters.conf if it doesn't find a /etc/default/cups file that tells it not to install.
To fix this behavior:
Remove the /etc/modules-load.d/cups-filters.conf file and check that kernel modules now load without errors:
sudo rm /etc/modules-load.d/cups-filters.conf
sudo systemctl restart systemd-modules-load.service
To make sure the file will not be recreated on the future updates, create a file /etc/default/cups with the following content:
sudo nano /etc/default/cups
# do not load parallel port modules
LOAD_LP_MODULES="no"
You may optionally test your work by reinstalling cups-filters and checking that /etc/modules-load.d/cups-filters.conf doesn't exist after te reinstall.
sudo apt-get install --reinstall cups-filters
PeterJamesRye
Re: SOLVED-Raspbian Jessie: failed to start Load Kernel Modules?
Sat Jan 27, 2018 8:14 am
A little down the track, but I had the same issue with a Respberry Pi, Model B, installing lubuntu 16.04. Could not get to any user interface, but I pulled out the SD card, edited the CUPS conf file (commenting out everything) on another Linux computer, and the next boot went perfectly OK.
ajayhakkumar
Thu Feb 15, 2018 8:30 am
Nothing works keyboard, mouse or any external devices connected to open kernel
Who is online
Users browsing this forum: Idahowalker and 67 guests
