vk4tec
perl script mixed in with a service
Fri Apr 08, 2016 9:50 am
Hello
I have a service in /etc/init.d
I want to tag on a perl script to run in the "start" condition of a script
Like service dump1090 start
This starts up dump1090 plus the perl script. Do I just add the perl script in the start section of
/etc/init.d/dump1090?
I think u need sudo for "service" ?
Andrew
solar3000
Re: perl script mixed in with a service
Fri Apr 08, 2016 1:54 pm
just make the file executable and name it somefile.pl
it should run like any script.
Antikythera
Sat Apr 09, 2016 12:42 pm
solar3000 wrote:just make the file executable and name it somefile.pl
The file name doesn't matter. somefile or somefile.pl or some.file.with.a.made-up.suffix.xyzzy will all execute in exactly the same way.
The crucial part of getting a perl program running is the shebang (#!) line at the top of the file and giving the file the executable permission bits.
#!/usr/bin/perl
or
#!/usr/bin/env perl
both work.
Sat Apr 09, 2016 12:57 pm
vk4tec wrote: Do I just add the perl script in the start section of
1. Everything run as an init.d script runs as root until your program changes it. You don't need sudo.
2. The stuff in /etc/init.d/xxx is a bash script that gets your real program running as a service
3. Do NOT add your perl program in your /etc/init.d script, store your perl program in /usr/local/bin
4. With Raspbian Jessie and Ubuntu MATE stop using /etc/init.d, write a systemd service file and get that starting your service. It's a whole bunch easier that init.d anyway (once you've got your first service running).
https://www.digitalocean.com/community/ ... he-journal
https://www.digitalocean.com/community/ ... unit-files
