Yes, I know. I have searched on that but can't find anything useful of that. :-/
I suddenly got this when I tried:
May 7 23:33:09 raspberrypi wpa_supplicant[413]: wlan0: Associated with 38:18:38:58:31:41
May 7 23:33:09 raspberrypi kernel: [ 14.485376] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
May 7 23:33:09 raspberrypi bluetoothd[604]: Bluetooth daemon 5.23
May 7 23:33:09 raspberrypi systemd[1]: Started Bluetooth service.
May 7 23:33:09 raspberrypi systemd[1]: Starting Bluetooth.
May 7 23:33:09 raspberrypi systemd[1]: Reached target Bluetooth.
May 7 23:33:09 raspberrypi bluetoothd[604]: Starting SDP server
May 7 23:33:09 raspberrypi kernel: [ 14.572766] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
May 7 23:33:09 raspberrypi kernel: [ 14.572786] Bluetooth: BNEP filters: protocol multicast
May 7 23:33:09 raspberrypi kernel: [ 14.572809] Bluetooth: BNEP socket layer initialized
May 7 23:33:09 raspberrypi dbus[411]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
May 7 23:33:09 raspberrypi bluetoothd[604]: Bluetooth management interface 1.10 initialized
May 7 23:33:09 raspberrypi systemd[1]: Starting Hostname Service...
May 7 23:33:09 raspberrypi bluetoothd[604]: Sap driver initialization failed.
May 7 23:33:09 raspberrypi bluetoothd[604]: sap-server: Operation not permitted (1)
May 7 23:33:09 raspberrypi systemd-hostnamed[607]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
May 7 23:33:09 raspberrypi dbus[411]: [system] Successfully activated service 'org.freedesktop.hostname1'
May 7 23:33:09 raspberrypi systemd[1]: Started Hostname Service.
May 7 23:33:12 raspberrypi wpa_supplicant[413]: wlan0: CTRL-EVENT-DISCONNECTED bssid=38:18:38:58:31:41 reason=0 locally_generated=1
May 7 23:33:12 raspberrypi wpa_supplicant[413]: wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
May 7 23:33:12 raspberrypi wpa_supplicant[413]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="My-network" auth_failures=1 duration=10 reason=WRONG_KEY
May 7 23:33:12 raspberrypi wpa_supplicant[413]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
May 7 23:33:12 raspberrypi kernel: [ 17.487380] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
May 7 23:33:12 raspberrypi kernel: [ 17.487409] cfg80211: World regulatory domain updated:
May 7 23:33:12 raspberrypi kernel: [ 17.487418] cfg80211: DFS Master region: unset
May 7 23:33:12 raspberrypi kernel: [ 17.487428] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
May 7 23:33:12 raspberrypi kernel: [ 17.487442] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
May 7 23:33:12 raspberrypi kernel: [ 17.487454] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
May 7 23:33:12 raspberrypi kernel: [ 17.487466] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
May 7 23:33:12 raspberrypi kernel: [ 17.487480] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
May 7 23:33:12 raspberrypi kernel: [ 17.487495] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
May 7 23:33:12 raspberrypi kernel: [ 17.487507] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
May 7 23:33:12 raspberrypi kernel: [ 17.487519] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
May 7 23:33:12 raspberrypi kernel: [ 17.487531] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
May 7 23:33:12 raspberrypi wpa_supplicant[413]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=SE
May 7 23:33:12 raspberrypi kernel: [ 17.522014] cfg80211: Regulatory domain changed to country: SE
May 7 23:33:12 raspberrypi kernel: [ 17.522036] cfg80211: DFS Master region: ETSI
May 7 23:33:12 raspberrypi kernel: [ 17.522045] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
May 7 23:33:12 raspberrypi kernel: [ 17.522059] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
May 7 23:33:12 raspberrypi kernel: [ 17.522075] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
May 7 23:33:12 raspberrypi kernel: [ 17.522089] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
May 7 23:33:12 raspberrypi kernel: [ 17.522102] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
May 7 23:33:12 raspberrypi kernel: [ 17.522114] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
May 7 23:33:12 raspberrypi wpa_supplicant[413]: wlan0: Trying to associate with SSID 'My-network'
May 7 23:33:13 raspberrypi wpa_supplicant[413]: wlan0: CTRL-EVENT-ASSOC-REJECT status_code=16
May 7 23:33:13 raspberrypi wpa_supplicant[413]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="My-network" auth_failures=2 duration=20 reason=CONN_FAILED
I am 100 % SURE it is the right key!
I suspect it can be hardware error or some major error in the installation, and will probably try to reinstall everything some day.
