pitony
can't edt cnfg txt file
Sun Apr 03, 2016 12:14 pm
hello all
new to both the forum and pi, have installed 7" monitor but display is upside down.
edited txt file with new line
lcd_rotate=2
tried to save file but the file cannot be re written to.
any advice on how to get access to edit and save to the txt file would be really helpfull.
thanks in advance
tony
have searched forum but cannot find relevant info. not too technical but can follow instructions OK.
darkbibble
Re: can't edt cnfg txt file
Sun Apr 03, 2016 12:56 pm
load up terminal, switch to the folder the file is in, then type "sudo nano filename"
Q; How many Windows users does it take to fix a Linux problem??
A; Whats a Linux problem
FTrevorGowen
Sun Apr 03, 2016 12:58 pm
pitony wrote:hello all
lcd_rotate=2
thanks in advance
tony
What editor are you using? Are you editing on the Pi itself? If using an editor from the command line did you precede the command with sudo? Eg.:
sudo nano /boot/config.txt
(I suspect you have a "file permissions problem")
Trev.
Rive
Sun Apr 03, 2016 1:01 pm
Two ways:
On a PC (or Apple or Android device) open using word, or native text editor:
Insert micro sdccard in to reader, then open 'config.txt' file, make changes, save file. Then insert sdcard into pi.
In a terminal screen on pi itself:
To SAVE changes:
Hold 'Ctrl' and 'x' at same time, then 'y', then 'enter'
Then, in terminal:
sudo reboot
DNPNWO
pitony
Sun Apr 03, 2016 1:28 pm
He all
many thanks for the replies, i used the terminal and have now got a display the right way up.
forums are great
regards
tony
Return to “Beginners”
