rzusman
Multiple programs using pigpio
Thu Mar 31, 2016 2:17 am
What is the proper way to handle pigpio's initialization if there are multiple programs that need to run simultaneously?
Specifically, I have a background task which never quits, and must call gpioInitialise to monitor an IO pin. If I try to launch another program gpioInitialise fails with error -1 (presumably because it's already initialized). How should I handle this?
joan
Re: Multiple programs using pigpio
Thu Mar 31, 2016 4:03 am
The other programs will have to use the socket or pipe interface to access the running library.
Only one program directly linked with the pigpio library can be run at a time (that program becomes the pigpio daemon).
That's how the Python module works. With C use http://abyz.co.uk/rpi/pigpio/pdif2.html
Return to “Advanced users”
