KYkid85
Cannot save config.txt file
Wed Mar 30, 2016 7:23 pm
So I noticed that i was overclocking by 100MHz
Went to File manager/boot/config.txt and changed to 700MHz but i would not save
Just said "Can't Open file to write" Is this normal?
I ended up sudo reboot then hit shift during startup and (e) then changed it manually from there. But in the future i want to know if I can change it without having to reboot.
-thanks
Re: Cannot save config.txt file
Wed Mar 30, 2016 7:42 pm
You need to be root to update that file. Open an LXTerminal window and use sudo nano /boot/config.txt to edit it.
Rive
Wed Mar 30, 2016 8:31 pm
To save 'Ctrl' key and 'x' at same time, then 'y', then 'enter'. then reboot to enable changes (you can also edit txt file with a txt editor).
DNPNWO
