krishnancr wrote:@MrEngman,
My WDN3200 seems to work fine on my windows laptop and connects to the router straight away but when i plug it in to the pi, i see nothing. I've tried plugging it in directly and thru a hub.
So as long as the wi fi dongle connects to the internet on a normal PC , just plugging it to the pi zero should just work right ?
Appologies if the questions are too dumb
I think you will need an adapter cable, OTG cable??, plugged into the Pi Zero to get the USB to operate in host mode otherwise the Pi Zero will operate as a USB device and will not connect to and recognise other USB devices. So what cable have you used to connect your wifi/hub to the Pi Zero? That could be your problem.
Otherwise it should work as the drivers are included in the kernel image. (rt2800usb)
I have a Pi Zero sat next to me with a WDN3200 wifi connected and it is working OK. I am connected to it via SSH and wifi and commands lsusb and lsmod show
pi@Pi-0a:~ $ lsusb
Bus 001 Device 002: ID 148f:5572 Ralink Technology, Corp. RT5572 Wireless Adapter
pi@Pi-0a:~ $ lsmod
Module Size Used by
ctr 4005 1
ccm 8334 1
arc4 1956 2
rt2800usb 18741 0
rt2800lib 81939 1 rt2800usb
rt2x00usb 11912 1 rt2800usb
rt2x00lib 47782 3 rt2x00usb,rt2800lib,rt2800usb
mac80211 595702 3 rt2x00lib,rt2x00usb,rt2800lib
cfg80211 479223 2 mac80211,rt2x00lib
crc_ccitt 1620 1 rt2800lib
rfkill 21508 2 cfg80211
MrEngman
