I've been having a bit of trouble with powering the raspberry pi. Note I am using a 2500mah lipo battery, connected to an adafruit powerboost 500c, connected to the gpio 5v and gnd on the pi. The setup used to work but has started to fail. At first the power seems to run as normal but then cut out after 10 seconds or so. The soldering is all correct I believe as it has been checked over many a time and there is not much to go wrong anyway. Is there anything obviously wrong with my setup or is there another way to power that isn't micro USB or the USB port?
Also note that the battery positive connection goes through a switch and then to the power boost but when charging the raspberry pi's power light lights up dimly. I don't think that this is a problem but it is something that might be considered I suppose.
All help is very much appreciated!
Thanks,
Calum.
Pictures: http://imgur.com/a/U0Wvz
