1. How does one locate the attached drive? Neither lsusb nor df sees it.
pi@raspberrypi:~ $ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 3661568 880560 2606876 26% /
devtmpfs 218416 0 218416 0% /dev
tmpfs 222688 0 222688 0% /dev/shm
tmpfs 222688 4528 218160 3% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 222688 0 222688 0% /sys/fs/cgroup
/dev/mmcblk0p1 61384 20368 41016 34% /boot
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 0557:2213 ATEN International Co., Ltd CS682 2-Port USB 2.0 DVI KVM Switch
Bus 001 Device 005: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 001 Device 004: ID 0b95:772b ASIX Electronics Corp. AX88772B
Bus 001 Device 003: ID 1058:25a7 Western Digital Technologies, Inc.
Bus 001 Device 002: ID 0424:2533 Standard Microsystems Corp.
pi@raspberrypi:~ $
