paul4ar
Auto-login to Raspbian desktop with own username?
Sat Mar 26, 2016 10:13 pm
Using Raspian Jessie here. I initially used the raspi-config tool to set my system to auto-login to the desktop environment as user pi. However, later, I deleted and replaced user pi with user paul in the appropriate places and this works fine; except for one thing: I now no longer can auto-login to the desktop environment and it now prompts for the password.
How do I set user paul to autologin to the desktop environment?
Thanks,
Paul.
Re: Auto-login to Raspbian desktop with own username?
Sun Mar 27, 2016 12:12 am
Edit /etc/systemd/system/autologin@.service and change the one occurence of 'pi' in that file to 'paul'
Languages using left-hand whitespace for syntax are ridiculous
DMs sent on Twitter/LinkedIn will be answered next month.
The use of crystal balls and mind reading is prohibited.
federicosibella
Thu Jun 16, 2016 2:16 pm
Hello, I have the same request.
I tried changing the file that paul4r mentioned but the autologin doesn't work
If I remove the check for autologin from raspy-config utility rebooting the PI i get the login window. If I enable the autologin option it starts with Pi login automatically. :?:
Is there any other option to check?
thank you in advance
Federico
JimmyN
Thu Jun 16, 2016 2:59 pm
federicosibella wrote: If I remove the check for autologin from raspy-config utility rebooting the PI i get the login window.
That sounds correct, without autologin you'll get the login window.
That sounds correct as well, since the user "pi" is hardcoded for the autologin.
If you want to autologin with a user other than "pi", then read and follow @Dougie's post.
Romonga
Thu Jun 16, 2016 6:21 pm
My understanding is that this is controlled in /etc/lightdm/lightdm.conf
There is a line in there that reads autologin-user=pi
i simply placed my username in that file, rebooted and it auto-logged me in with that id.
You can run, but you will only die tired.
federicosibella
Thu Jun 16, 2016 6:34 pm
Romonga wrote:My understanding is that this is controlled in /etc/lightdm/lightdm.conf
This is what I did but it didn't work. I edited the lightdm.conf file placing instead of PI user my new user in the auto-logon parameter line. I rebooted the Raspberry and it started again with PI logged in... The other tests I described in my post were made just to check auto logon and not auto logon in order to test my new created user...
Romonga
Thu Jun 16, 2016 7:36 pm
Odd, When I wanted to get rid of the default user I did the following.
Create User
sudo adduser <username>
Add user to groups
sudo usermod -a -G pi,adm,dialout,cdrom,sudo,audio,video,plugdev,games,users,input,netdev,spi,i2c,gpio,pi-share <username>
sudo nano /etc/lightdm/lightdm.conf
Replaced =Pi to my user id.
I rebooted and autologon worked.
federicosibella
Mon Jun 20, 2016 6:27 am
thank you for your reply but if I do like this my user will be automatically added to th e admins group isn't it?
that's not good for my requirements since my autologged user must not be a privileged user
federicosibella
Mon Jun 20, 2016 6:49 am
SOLVED
since I made many tests on this installation I decided to format the Sd card and make a new Raspbian installation
After that i created my user, edited the lightdm.conf file and... it worked fine....
thank you for the support!
