flameboy5073
Overwriting my SD card
Fri Aug 10, 2012 11:06 am
I have put all the wheezy files onto my sd card it is not working so i want to try writing them again. but then ill have 2 lots of files how do i do it so there is only 1 set of files. Window cant format the card as only linux can read most of it. help please
thanks :ugeek:
drgeoff
Re: Overwriting my SD card
Fri Aug 10, 2012 11:09 am
When you write another image it will overwrite the existing one. The previous files will be gone.
Jim JKla
Fri Aug 10, 2012 1:29 pm
If you are using dd or Win32DiskImage you can read your old files to a new image name before you write the new set then if you want to back track you can use that as your own personalised image.
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
