DanLap
Button click opens new webpage
Fri Mar 25, 2016 3:48 pm
I currently have a python script that when clicking a button on our webpage causes the python script to move a motor. However, each time the button is clicked it opens a new page rather than just refreshing the page. Each time I have to press the back button to go to our main page. I have tried a bunch of things but would like to have the page just refresh when clicking the button. Any suggestions? My python code is below.
#! /usr/bin/env python
import cgi
import serial
ser = serial.Serial('/dev/ttyACM0',9600)
ser.write('z050\n') #this is what moves motor (connected to arduino)
ser.close()
print("Content-type: text/html\n\n"
print<html>These words show up on the new page once button is clicked></html>"
TheConsciousness
Re: Button click opens new webpage
Tue Mar 29, 2016 5:22 pm
Are you sure that is the only code you're using?
Also, your print statements don't have the write about of quotation marks or parenthesis.
scotty101
Wed Mar 30, 2016 10:44 am
Can you share the HTML of the page that has the button on it.
As the previous poster mentioned, the python code you posted will not work.
You might want to consider using python-flask rather than CGI.
DanLap
Wed Mar 30, 2016 4:46 pm
I had just put those print statements as an example, fixed below
import cgi
import serial
ser.close()
print"<html>These words show up on the new page once button is clicked></html>"
Our HTML is just a simple page that has buttons to move the motor up/down/left/right. When the button is clicked the motor moves correctly but the webrowser goes to a page showing the html in the python script. Here is a sample of where we have in HTML for the buttons:
#HTML buttons with up/down/left/right arrows
    <table>
		<tr><td></td><td><a href="/cgi-bin/moveup.py"><button> &#9650 </button><br></td></tr><td></td>
		<tr>
			<td><a href="/cgi-bin/moveleft.py"><button>&#9668</button><br></td>
			<td></td>
			<td><a href="/cgi-bin/moveright.py"><button>&#9658</button><br></td>
		</tr>
		<tr><td></td><td><a href="/cgi-bin/movedown.py"><button>&#9660</button><br></td></tr><td></td>
    </table>
DanLap
Wed Mar 30, 2016 4:49 pm
I have been thinking about using flask or even webiopi but wanted to see if I could get everything to work using just the CGI and HMTL. Basically just want to see if I could get the button to refresh the html page or just open the page in a second tab rather than going right to the html in the python code. If we don't put the line of HTML, it just goes to a blank page when the button is clicked.
Is this even possible? I am not sure if the fix would be with python or the index.html page
scotty101
Thu Mar 31, 2016 8:27 am
Problem is with the python script.
When you press the button it navigates to the new page. You have have it redirect back to your index page once the motor has been moved.
http://stackoverflow.com/questions/6122 ... cgi-python
Again. This is much simpler with python-flask.
mysen
Fri Apr 01, 2016 11:35 am
This is what you code needs to look like...
import cgi, cgitb
import serial
ser.close()
print "Content-type: text/html\n\n"
print "<head>"
print "<meta http-equiv="refresh" content="0; url=http://button-url-or-ip" />"
print "</head>"
content = how many seconds to wait until going to the specified URL. I think in your case 0 is fine. and the url should just be where to you want it to redirect to, in your case back to the url your just came from.
Hope this helps
elParaguayo
Fri Apr 01, 2016 1:36 pm
This line
is going to give you a SyntaxError because of you're using the same quotation marks to start your string and also inside the string.
Try:
print """<meta http-equiv="refresh" content="0; url=http://button-url-or-ip" />"""
or
print '<meta http-equiv="refresh" content="0; url=http://button-url-or-ip" />'
I'd also second the comments about Flask, it's very easy to use and cgi always seemed overly complicated to me. But go with what you know!
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
DanLap
Fri Apr 01, 2016 5:16 pm
Thank you so much!! This worked perfectly for what I was looking for using just the cgi. Will definitely be looking into flask very soon.
Return to “Python”
