S-USV
New UPS for Raspberry Pi - S.USV
Tue Mar 22, 2016 9:35 am
Dear community,
We are a German company which created an UPS for the Raspberry Pi named “S.USV” and we would
like to ask for your opinion. Our uninterruptable power supply with integrated
charger and mobile application is compatible with all Raspberry Pi models.
Currently we are only represented on the German market. We really would like to know what
functions would be interesting for you guys? Or if there is a general need of
an uninterruptible power supply for your Pis.
Here the main functions are listed:
- HAT compliant UPS Module
- Compatible with Pi 3 and Pi 2 Model B, Pi A+, Pi B+
- Adapter solution for Pi Model A and B
- Uninterruptible power supply
- Plug & Play
- Monitoring – System
- Intelligent software solution
- Built-in LiPo battery (300mAh) with adjustable charging function
- Battery Management Controller
- Battery Monitoring System
- Power input with extended voltage range of 7-24 volts
- Integrated Real Time Clock
- Time-controlled on and off switching of the Raspberry Pi
- LED – Status display
- Bootloader for Live – Firmware Updates
Thank you so much
for your help.
Wish you a nice day!
BR,
Chris
shollz
Re: New UPS for Raspberry Pi - S.USV
Tue Mar 22, 2016 6:47 pm
Chris,
I would be very interested in this. I built a mobile plex server and would like a ups system that would generate a safe shutdown upon power loss and work well with a vehicle's 12v system. Let me know if I can purchase one or test one. Thanks
Craig
S-USV
Wed Mar 23, 2016 7:27 am
Craig,
Thanks a lot and please have a look at your private message.
BR,
Chris
Jednorozec
Thu Mar 24, 2016 9:23 am
I'm interested in this too.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
S-USV
Tue Mar 29, 2016 9:17 am
Thanks for your interest.
Please have a look at your PM.
dantose
Tue Mar 29, 2016 9:22 am
Not sure what price point you are going for, but the battery size seems pretty puny. 2-3000 mah portable charges are sub $10 and would be something I'd be interested in for a pi
wayner
Wed Mar 30, 2016 3:05 am
The capability to charge the battery from a solar panel would be nice for remote applications that don't have connections to the grid.
java
Wed Mar 30, 2016 7:00 am
wayner wrote:The capability to charge the battery from a solar panel would be nice for remote applications that don't have connections to the grid.
I'd rather build a Solar Charging device, which would be independent of the RPi, and plugged into the standard power connecter on the RPi ... , just my preference.
ramoons
Thu May 23, 2019 6:03 pm
Dear Chris,
I’m not sure you are following this post after 3 yers, but I’m very interested in S.USV for my Raspberry Pi 3 B+, which was converted into AirPlay and is being used in my car. I’m looking for solution how not to lose power and continue listening music for a while when engine is being switched off.
Is this product still available? Where I can buy one of these?
ramoons
mahjongg
Fri May 24, 2019 8:40 am
Nope, S-USV has not posted here since his first three posts here.
use google....
Andyroo
Fri May 24, 2019 12:39 pm
You will end up https://olmatic.de/en/products/susv/ and over £200 on Mouser U.K. :shock:
