here is the basic of the code
if motionVallue == 3 when on is pressed in android 3 comes as value in python
then it search for the input from the motion sensor
infinite loop
if motionValue == 2
stop the motion sensor
This is not working. i can turn on the motion sensor. then the loop continues. and it never accepts motionValue == 2 part. It just continue the motion.. I did try using break. Then it stop sensing. Any ideas on how to make the motionValue == 2 work..The loop should be continuous and when press off button it should off the motion sensor and if on the motion sensor should be on without the programming terminating.
