Is it possible to give signal directlly from raspberry to Electromagnetic lock, to open ?
http://www.electro-tech-online.com/cust ... ocks-1.jpg
How far away from the lock will the RPi be? You can use a 5V relay board powered from the RPi or a 12V 24V relay if powered by the lock power supply depending on which voltage you want to use for the lock.gigi5 wrote:What relay board would be best ? and i didnt understod part about "release button terminals"
You forgot one very important item. The circuit board. Not feasible for most novice users though a 'proto' board would work.solar3000 wrote:All you need are two transistors, some resistors, a diode and a relay.
