MAHAD93
Help for Wifi connection
Sat Mar 19, 2016 8:34 pm
Hi all, I need a way to a wifi network dynamically via command line...
Since, this needs to a portable solution for a project I cannot create a file for WPA_SUPPLICANT...and if I try to connect to wifi directly via WPA_SUPPLICANT it needs a driver, and none of the provided drivers work...I have a TP-LINK TL-WN725N wifi dongle.
Please, ANY help would be greatly appreciated!..I can connect just fine via the GUI.
You can read more about my Project, Documented here:
viewtopic.php?t=136082
:roll: THANKS IN ADVANCE :roll:
DirkS
Re: Help for Wifi connection
Sat Mar 19, 2016 9:13 pm
MAHAD93
Sun Mar 20, 2016 4:51 pm
Thankyou, I'm also using an Edimax dongle...The wifi seems to work and connect fine via GUI to WPA networks, So i guess drivers are there...It's command line wpa_supplicant that causes issue...
MAHAD93
Thu Mar 24, 2016 12:06 pm
:cry: BUMP :cry:
