TomiL
Custom time interval between SPI characters
Thu Mar 17, 2016 5:34 pm
I have SPI slave device connected to my RaspberryPi 1 (revison "000e", model B, manufactured by Sony, SPI IC family = BCM2708, implementation BCM2835). My device vendor suggest to interface the device in this way: first send command byte (0x03), wait for at least 10mS and then send data byte (0x04). I tried to do this with python (via py-spidev library), but when using 2 separate "spi.xfer()" command (or "spi.xfer2()"; btw, they do the same) I get ChipSelect assert between them:
import spidev
import time
spi = spidev.SpiDev()
spi.open(0,0)
spi.mode = 0b01
resp1 = spi.xfer([0x03], 500, 10000)
resp2 = spi.xfer([0x04], 500, 10000)
On oscilloscope it looks like that:
2 single "xfer" commands
Then I tried with array of commands:
resp = spi.xfer([0x03, 0x04], 500, 10000)
but than I can not get required 10mS gap between sequential command and data byte:
The place where I need custom interval
How can I extend time gap between SPI commands without CS assert (red marker)? Do I need to modify C library ("spidev_module.c" or even BCM2708 driver) to accomplished that or can that be done some other way?
joan
Re: Custom time interval between SPI characters
Thu Mar 17, 2016 7:35 pm
It may be simplest if you just control the slave select line yourself. Choose a spare GPIO for your own slave select and connect it to your device. Keep it high normally. Set it low before and high after your SPI commands.
TheRayTracer
Thu Mar 17, 2016 10:51 pm
According to the documentation: http://tightdev.net/SpiDev_Doc.pdf
There is a subtle difference between the use of xfer() and xfer2(). xfer() - "CS will be released and reactivated between blocks" and xfer2() - "CS will be held active between blocks". In your case I would recommend to use xfer2(). I would also recommend following Joan's advice to use a spare GPIO pin to drive the CS on your slave. This way you can manually hold it active and have full control over it.
TomiL
Fri Mar 18, 2016 11:29 am
Joan, I will definitely try your proposed solution.
TheRayTracer, I did investigate difference between .xfer() and .xfer2() in documentation, but in practice these command do the same, if the one try to send array of commands (I checked it on oscilloscope). Btw, this has been already reported a few times by different sources, e.g. viewtopic.php?t=39384&p=323721 (look at post by drdavros).
