nikhil sasne
temperature sesing and wifi
Thu Mar 17, 2016 8:10 am
hello there,
I m designing a system in that want to monitor temperature of room continuously so, in this case can raspberry pi product has such temperature sensors in build or i have to connect them externally.
Also, I want to transfer sensed temperature data through wi-fi. so, my question is, is it doable in Raspberry pi product?
if yes, then which product should i pickup?
Regard,
nikhil
scotty101
Re: temperature sesing and wifi
Thu Mar 17, 2016 8:41 am
The raspberry pi does have a built in temperature sensor but it will only tell you the temperature of the CPU which is way hotter than the surrounding environment.
The common solution is to use a DS18B20.
There are lots of tutorials out there but here is one
https://learn.adafruit.com/adafruits-ra ... g/hardware
In terms of the WiFi element of your project.. what do you want to send it to?
I have mine setup through my home automation system so that I can browser to a webpage on my home network and see the temperature.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
nikhil sasne
Thu Mar 17, 2016 8:56 am
hello sir,
Thanks for reply.
Actually my requirement is that, if I have interfaced a temperature sensor with Raspberry pi, then in this case i want to send temperature value which is sensed by the temperature sensor to my computer using wi-fi.
so, meaning is that can wi-fi dongal connected to raspberry pi be used as transmitter for data sending ?
Regards,
Nikhil
RaTTuS
Contact: Twitter YouTube
Thu Mar 17, 2016 9:02 am
yes - if you have a Rpi3 then it has on-board wifi also bluetooth - both can connect to another device -
so you can connect to a wireless network via wi-fi
and direct to a device via bluetooth
Covfefe
nikhil sasne
Thu Mar 17, 2016 9:05 am
hi,
thanks for reply it really gonna help me!! :)
Return to “Beginners”
