geerlingguy
Raspberry Pi 3 microSD card overclock
Wed Mar 16, 2016 7:13 pm
I just wanted to post some test results here, since the only topics I've found dealing with microSD card overclocking seemed to be a bit scattered about, and there were no simple "step 1, step 2, step 3" guides to testing and benchmarking microSD performance on the Pi 2/Pi 3.
tl;dr: I finally received a Pi 3 a couple days ago, and wanted to test overclocking the microSD reader on it for my nicer UHS-1/UHS-3 cards (like the Samsung Evo+ and Pro+, and the SanDisk Extreme), and I've published instructions and benchmarks on my blog here: http://www.jeffgeerling.com/blog/2016/h ... berry-pi-3.
WARNING: If you care about your microSD card's contents, or don't know what you're doing, it's safest to not overclock.
With that out of the way, you need to do two things to set up the overclock (assuming you have the latest Raspbian version installed):
  • Add a dtoverlay in config.txt:
    sudo bash -c 'printf "dtoverlay=sdhost,overclock_50=100\n" >> /boot/config.txt'
  • Reboot the Pi.
Reboot the Pi, and you should now have an overclocked microSD reader.
There's a simple benchmark that tests large file operations that I've seen elsewhere; you can run it quickly with:
curl http://www.nmacleod.com/public/sdbench.sh | sudo bash
The benchmark I typically use (which tests 4K read/write using iozone) is:
curl https://raw.githubusercontent.com/geerlingguy/raspberry-pi-dramble/master/setup/benchmarks/microsd-benchmarks.sh | sudo bash
The above scripts that you might be inclined to run through sudo bash are coming from either GitHub or someone's personal site... so always vet code before you run it on your own machine, and consider not using it if your Pi and the data on it is important to you :)
My personal site: http://jeffgeerling.com/
GTR2Fan
Re: Raspberry Pi 3 microSD card overclock
Wed Mar 16, 2016 7:23 pm
Just adding...
...to config.txt should work fine in a standard Raspbian Jessie install without having to do anything else.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
geerlingguy
Wed Mar 16, 2016 7:27 pm
GTR2Fan wrote:Just adding...
On my Pi 3 with Raspbian Lite (even after apt-get upgrade), I had to download the .dtb... I'm wondering if on regular Raspbian it gets placed correctly, but something's missing on Lite? Also, afaict, 'sudo rpi-update' isn't available on Lite either.
I hate using regular Raspbian for benchmarking because it's such a heavy image.
Nickcn
Wed Mar 16, 2016 7:36 pm
deleted
DirkS
geerlingguy wrote:On my Pi 3 with Raspbian Lite (even after apt-get upgrade), I had to download the .dtb... I'm wondering if on regular Raspbian it gets placed correctly, but something's missing on Lite? Also, afaict, 'sudo rpi-update' isn't available on Lite either
Just checked and sdhost-overlay.dtb *is* included in the latest Jessie Lite image (2016-02-26)...
rpi-update is not installed by default anymore
geerlingguy
Wed Mar 16, 2016 8:08 pm
DirkS wrote:Just checked and sdhost-overlay.dtb *is* included in the latest Jessie Lite image (2016-02-26)...
I'm cloning from 2016-02-26-raspbian-jessie-lite.img, which I downloaded from https://www.raspberrypi.org/downloads/raspbian/, and the sdhost-overlay.dtb is present, but not the sdtweak one... AH! Just now realized sdhost is all you need. D'oh!
I'll update the instructions.
Trixster
Wed Mar 16, 2016 8:32 pm
In my experience adding "dtoverlay=sdhost,overclock_50=100" stops the wifi adapter on an rpi3 from working.
Instead use "dtoverlay=sdtweak,overclock_50=100", assuming you have sdtweak in overlays. I had to copy it over from my openelec image.
geerlingguy
Wed Mar 16, 2016 8:38 pm
Trixster wrote:In my experience adding "dtoverlay=sdhost,overclock_50=100" stops the wifi adapter on an rpi3 from working.
Hmm, sounds like the issue that's been reported here, then: viewtopic.php?p=928516#p928516
So is sdtweak going to be added to the overlays? @PhilE's post from that thread, two days ago:
PhilE wrote:It's in the very latest firmware (sudo rpi-update) but may not have been built into a Raspbian update yet.
I'm not using the built-in WiFi at this time, so haven't tested with it at all. I used it for some benchmarking, but not in tandem with the sd overclocking.
GTR2Fan
Wed Mar 16, 2016 8:42 pm
Reading a few posts up from that one by PhilE makes it look as though a fix for the Pi3 is already available for dtoverlay=sdhost,overclock_50=100 via rpi-update and waiting to be pushed to main. I mistakenly thought that it was already properly sorted for the Pi3 in main. It looks as though it will be very soon. Apologies for any confusion caused.
DirkS
Wed Mar 16, 2016 9:08 pm
geerlingguy wrote:[So is sdtweak going to be added to the overlays? @PhilE's post from that thread, two days ago:
It's in the 'next' branch of the firmware repo:
https://github.com/raspberrypi/firmware ... t/overlays
ziddey
Thu Mar 17, 2016 4:44 am
Just use the dtparam:
dtparam=sd_overclock=100
Note: for rpi3, you'll need to rpi-update.
Rive
Thu Apr 28, 2016 12:21 am
ziddey wrote:Just use the dtparam:
No you don't.
it is in the apt-get update, apt-get upgrade, and all current Jessie dist versions since April or so.
DNPNWO
MartinPi
Mon May 30, 2016 9:50 am
What about Ubuntu Mate? Wish to overclock the card reader on it.
Raspberry Pi 3 32GB with 32-inch Monitor
Rasberry Pi Zero 32GB
cruster
Tue Nov 01, 2016 5:31 pm
Gosh! What a difference on my Sandisk Extreme. Thank you so much! :D
pimate2
Tue Dec 05, 2017 5:02 pm
Thank you!
rpi-update was not required on latest Stretch.
AnythingIsFine
Thu Apr 19, 2018 7:07 pm
I'm unable to overclock my microSD card reader to 100MHz on my Raspi 3 B Plus.
I have edited the
/boot/config.txt
file 4 times, each time adding only 1 of the below lines and rebooted, yet it never seems to be able to boot up.
#1.
, it would not boot up.
#2.
dtoverlay=sdhost,overclock_50=83
#3.
dtoverlay=sdtweak,overclock_50=83
#3.
After editing the config.txt it looks like the pi is unable to read/find microSD card, as I have no entries in my systemlog or dmesg that would hint what's happening.
* Has anyone encountered this issue and if not can someone with the same SW and HW setup please try to reproduce this ?
HW:
Raspberry Pi 3 B Plus board
Samsung Evo Plus 32GB microSD card
2.5A at 5.1 V official Raspberry PSU
OS:
Raspbian Strech 9.4 Lite and latest firmware as of 2018-04-19 (version c1f3e94f22866aa26e41b4d107e6e3741b917a98)
Thanks!
