cptwillem
Setting up Razberry on a Pi model 3B
Sun Mar 13, 2016 10:26 am
I had problems getting the Razberry Z-wave board to work with the new Raspberry model 3 B. After some major browsing I found a way to make it work. I thought I share;)
Hardware: Raspberry PI model 3 B and Razberry card on GPIO
Apparently the new BT port is blocking TTY communications on the PI3B. The temporary workaround is:
Update Raspbian to the latest:
sudo apt-get update
sudo apt-get upgrade
Update RPI3B firmware to the latest:
sudo apt-get install rpi-update
sudo rpi-update
After this: REBOOT
Disable BT on RPI3B:
Open the /boot/config.txt
sudo nano /boot/config.txt
At the end add the line:
dtoverlay=pi3-disable-bt
exit with ctrl-X, select Yes
After this: REBOOT
set the correct baudrate:
stty -F /dev/ttyAMA0 9600
Now you can restart or install your domotica package. I've tested this with latest releases of z-wave and domoticz
Hope this helps someone with the same problem!
Willem
briantilburgs
Re: Setting up Razberry on a Pi model 3B
Tue Mar 15, 2016 8:35 am
THANKS!! Working for me! :D
