caporeira
Can't upgrade image
Sat Mar 12, 2016 10:14 am
Hi, after command apt-get dist-upgrade or apt-get upgrade, at the of command I have error:
Extracting templates from packages: 100%
Preconfiguring packages ...
Setting up udev (215-17+deb8u3) ...
update-initramfs: deferring update (trigger activated)
insserv: warning: script 'Startscript' missing LSB tags and overrides
insserv: There is a loop between service watchdog and Startscript if stopped
insserv:  loop involving service Startscript at depth 2
insserv:  loop involving service watchdog at depth 1
insserv: Stopping Startscript depends on watchdog and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package udev (--configure):
 subprocess installed post-installation script returned error exit status 1
Processing triggers for initramfs-tools (0.120) ...
 udev
E: Sub-process /usr/bin/dpkg returned an error code (1)
What that mind and how to fix it ?
Re: Can't upgrade image
Sat Mar 12, 2016 10:58 am
There's your error.
edit /etc/init.d//Startscript and add
### BEGIN INIT INFO
# Provides:          Startscript
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Example initscript
# Description:       This file should be used to construct scripts to be
#                    placed in /etc/init.d.  This example start a
#                    single forking daemon capable of writing a pid
#                    file.  To get other behavoirs, implemend
#                    do_start(), do_stop() or other functions to
#                    override the defaults in /lib/init/init-d-script.
### END INIT INFO
right after the shebang line (which will be something like #!/usr/bin/bash)
caporeira
Sat Mar 12, 2016 6:58 pm
It works !! Thank you :)
