here is what the crash logs are saying i'm a noob please help.
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Mon Jan 16 15:35:01 EST 2017
Kodi Options:
Arch: armv7l
Kernel: Linux 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016
Release: Raspbian GNU/Linux 8 (jessie)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/pi/core (2017-01-16 15:35:01.912725253 -0500)
[New LWP 1419]
[New LWP 1420]
[New LWP 1434]
[New LWP 1427]
[New LWP 1431]
[New LWP 1430]
[New LWP 1429]
[New LWP 1432]
[New LWP 1428]
[New LWP 1426]
[New LWP 1433]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin --standalone'.
Program terminated with signal SIGABRT, Aborted.
#0 0x754ebf70 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
Thread 11 (Thread 0x703783b0 (LWP 1433)):
#0 0x7685ca40 in do_futex_wait (isem=isem@entry=0x72c02dfc) at ../nptl/sysdeps/unix/sysv/linux/sem_wait.c:48
#1 0x7685caf4 in __new_sem_wait (sem=0x72c02dfc) at ../nptl/sysdeps/unix/sysv/linux/sem_wait.c:69
#2 0x76398b60 in vchiu_queue_pop () from /opt/vc/lib/libvchiq_arm.so
#3 0x70bd9d70 in ilcs_task () from /opt/vc/lib/libopenmaxil.so
#4 0x763accc4 in vcos_thread_entry (arg=0x72c02cb8) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#5 0x76855e90 in start_thread (arg=0x703783b0) at pthread_create.c:311
#6 0x7558f598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 10 (Thread 0x6f5fe3b0 (LWP 1426)):
#0 0x7685ab30 in __pthread_cond_timedwait (cond=0x40686a8, mutex=0x40686e0, abstime=0x6f5fdd28) at pthread_cond_timedwait.c:199
#1 0x005e7304 in ActiveAE::CActiveAE::Process() ()
#2 0x01741ba8 in CThread::Action() ()
#3 0x01741e44 in CThread::staticThread(void*) ()
#4 0x76855e90 in start_thread (arg=0x6f5fe3b0) at pthread_create.c:311
#5 0x7558f598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 9 (Thread 0x72bff3b0 (LWP 1428)):
#0 0x75587f2c in ioctl () at ../sysdeps/unix/syscall-template.S:81
#1 0x76396010 in completion_thread () from /opt/vc/lib/libvchiq_arm.so
#2 0x763accc4 in vcos_thread_entry (arg=0x763a9318 <vchiq_instance+16>) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#3 0x76855e90 in start_thread (arg=0x72bff3b0, arg@entry=<error reading variable: Cannot access memory at address 0xc>) at pthread_create.c:311
#4 0x7558f598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
/home/pi/dev/gdb-7.7.1+dfsg/gdb/frame.c:472: internal-error: get_frame_id: Assertion `fi->this_id.p' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n) [answered Y; input not from terminal]
Create a core file of GDB? (y or n) [answered Y; input not from terminal]
############# END STACK TRACE ###############
################# LOG FILE ##################
15:35:01 T:1945276992 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:35:01 T:1945276992 NOTICE: -----------------------------------------------------------------------
15:35:01 T:1945276992 NOTICE: Starting Kodi (15.2 Git:02e7013). Platform: Linux ARM 32-bit
15:35:01 T:1945276992 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
15:35:01 T:1945276992 NOTICE: Kodi compiled Dec 28 2015 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
15:35:01 T:1945276992 NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.4.34-v7+
15:35:01 T:1945276992 NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
15:35:01 T:1945276992 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
15:35:01 T:1945276992 NOTICE: ARM Features: Neon disabled
15:35:01 T:1945276992 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:35:01 T:1945276992 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:35:01 T:1945276992 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
15:35:01 T:1945276992 NOTICE: special://home/ is mapped to: /home/pi/.kodi
15:35:01 T:1945276992 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
15:35:01 T:1945276992 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:35:01 T:1945276992 NOTICE: Local hostname: Josh_PI2
15:35:01 T:1945276992 NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
15:35:01 T:1945276992 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanSuspend
15:35:01 T:1945276992 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanHibernate
15:35:01 T:1945276992 NOTICE: load settings...
15:35:01 T:1945269168 NOTICE: Thread FDEventMonitor start, auto delete: false
15:35:01 T:1945276992 NOTICE: Found 2 Lists of Devices
15:35:01 T:1945276992 NOTICE: Enumerated PI devices:
15:35:01 T:1945276992 NOTICE: Device 1
15:35:01 T:1945276992 NOTICE: m_deviceName : HDMI
15:35:01 T:1945276992 NOTICE: m_displayName : HDMI
15:35:01 T:1945276992 NOTICE: m_displayNameExtra:
15:35:01 T:1945276992 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:35:01 T:1945276992 NOTICE: m_channels : FL,FR
15:35:01 T:1945276992 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
15:35:01 T:1945276992 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
15:35:01 T:1945276992 NOTICE: Device 2
15:35:01 T:1945276992 NOTICE: m_deviceName : Analogue
15:35:01 T:1945276992 NOTICE: m_displayName : Analogue
15:35:01 T:1945276992 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:35:01 T:1945276992 NOTICE: m_sampleRates : 48000
15:35:01 T:1945276992 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
15:35:01 T:1945276992 NOTICE: Device 3
15:35:01 T:1945276992 NOTICE: m_deviceName : Both
15:35:01 T:1945276992 NOTICE: m_displayName : HDMI and Analogue
15:35:01 T:1945276992 NOTICE: Enumerated ALSA devices:
15:35:01 T:1945276992 NOTICE: m_deviceName : default
15:35:01 T:1945276992 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
15:35:01 T:1945276992 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
15:35:01 T:1945276992 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
15:35:01 T:1945276992 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
15:35:01 T:1945276992 NOTICE: m_deviceName : pulse
15:35:01 T:1945276992 NOTICE: m_displayName : PulseAudio Sound Server
15:35:01 T:1945276992 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
15:35:01 T:1945276992 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<video>
<defaultplayer>dvdplayer</defaultplayer>
<defaultdvdplayer>dvdplayer</defaultdvdplayer>
</video>
<gui>
<algorithmdirtyregions>3</algorithmdirtyregions>
<nofliptimeout>0</nofliptimeout>
</gui>
<splash>false</splash>
<lookandfeel>
<enablerssfeeds>false</enablerssfeeds>
</lookandfeel>
<cputempcommand>sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</cputempcommand>
<gputempcommand>/opt/vc/bin/vcgencmd measure_temp | sed "s,temp=\([0-9]*\)\.[0-9]'C,\1 C,"</gputempcommand>
</advancedsettings>
15:35:01 T:1945276992 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:35:01 T:1945276992 NOTICE: Default DVD Player: dvdplayer
15:35:01 T:1945276992 NOTICE: Default Video Player: dvdplayer
15:35:01 T:1945276992 NOTICE: Default Audio Player: paplayer
15:35:01 T:1945276992 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:35:01 T:1945276992 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:35:01 T:1945276992 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:35:01 T:1945276992 NOTICE: Loaded playercorefactory configuration
15:35:01 T:1945276992 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:35:01 T:1945276992 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:35:01 T:1868555184 NOTICE: Thread ActiveAE start, auto delete: false
15:35:01 T:1935668144 NOTICE: Thread AESink start, auto delete: false
15:35:01 T:1858073520 NOTICE: Thread CRBPWorker start, auto delete: false
15:35:01 T:1945276992 ERROR: SQL: SQL error or missing database
Query: SELECT idVersion FROM version
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
