aminatma
roasted micro sd card
Thu Mar 10, 2016 2:39 am
so annoyed , i don't know what to do , am I bad? my raspberry pi2 is it sick?
For two weeks I have my raspberry pi2 , I roasted three micro sd cards (overheating ? , Cracked in the middle)
Is raspberry card the cause? Or may be an incorrect operation could roast an sdcard?
I have no much time to send raspberry back to the supplier.
Did you know this Problem ?Am I the lonely noobs to encounter this problem ?
I have found nothing on the Internet.
I have :
- installed NOOBS OK
- functioning ok
-extract sd card
-put it in my UBUNTU computer to clone sdcard ok
-put it in rapsberry , start it ok
-reboot non ok , led red and green fixed
-extract sd card cracked by the middle , dead
SOS , I dare not touch it.
aminatma
Pi_Fanatic
Re: roasted micro sd card
Thu Mar 10, 2016 4:27 pm
aminatma, a little more information is needed to assist you. What cards are you using, where did you purchase them ?
RaTTuS
Contact: Twitter YouTube
Thu Mar 10, 2016 4:39 pm
post pictures using imgur.com
Covfefe
aminatma
Thu Mar 10, 2016 5:21 pm
hi,
thank you for your answer
some details:
first micro sd toshiba ( i am not sure ) 32go
second kingston classe 10 32 go amazon (new)
third pny classe 10 32 go french supermarket (new)
with two different power supply
the problem seems occur , when i extract the sd card, and put it on again ( i wanted to clone it with ubuntu)
first boot ok, second boot sd card broken....
I hope you understand the problem , sorry for my english, i am french.
best regards
nat
RaTTuS
Fri Mar 11, 2016 7:47 am
without seeing images I have to say MEh
viewforum.php?f=65 may be better to explain better
[your English is better than my French]
if there is a problem then you may have to return the RPi to your vendor
I've never seen cracked micro sdcards before
Covfefe
aminatma
Fri Mar 11, 2016 3:58 pm
aminatma
Fri Mar 11, 2016 4:19 pm
the third toast
thank you very much,I will follow your advise.
I will buy new P3 , I hope to have more luck.
thank you very much
few words more, find enclosed the picture of the third card :
the first i tought bad luck direct to the trash
the second , new from vendor , i tought it has defect direct to the vendor
the third see the picture
you can correct my spelling mistake , you will help me[img][img][/img][/img]
nat
