RPY63
Migrate from Raspberry PI2 to PI3
Wed Mar 09, 2016 12:29 pm
I've just received the Raspberry PI3.
To test ,I've moved the SD with Debian and all setting done on the RPI2 on the RPI3 but nothing happen and just the red led is on.
At this point I suppose that I can't use the same card on both PI version , and sound logic, but is there any way to transfer all the configurations,drives ,setting done Debian for the RPI2 on the new SD that I'll create for RPI3 ?
Does exist also a way to understand all drives ,setting , configuration and applications that are present on my actual Debian for RPI2 , so that I can easly search , install and apply the same on the new Debian for RPI3 ?
Thanks.Roberto
Re: Migrate from Raspberry PI2 to PI3
Wed Mar 09, 2016 5:35 pm
RPY63 wrote:I've just received the Raspberry PI3.
Thanks.Roberto
Debian are you sure ? Did you mean Raspbian Jessie or Debian Wheezy ? ?
RPi 4B 4GB (SSD Boot)..
RPY63
Wed Mar 09, 2016 6:02 pm
Debian Wheezy.
Wed Mar 09, 2016 6:10 pm
RPY63 wrote:Debian Wheezy.
Both Debian & Raspbian Wheezy are end of life...
.........since September 2015 Raspbian Jessie is the recommended Operating System and the latest release fully supports the RPi 3B: https://www.raspberrypi.org/downloads/raspbian
RPY63
Wed Mar 09, 2016 6:26 pm
Is there any way to upgrade Wheezy to Jessie using "dist-upgrade" or do I've to reinstall Jessie from scratch
and then recustomise ?
Thanks.
Wed Mar 09, 2016 7:03 pm
RPY63 wrote:Is there any way to upgrade Wheezy to Jessie using "dist-upgrade" or do I've to reinstall Jessie from scratch
Thanks.
You can upgrade Raspbian Wheezy to Raspbian Jessie
viewtopic.php?f=66&t=121880
I have never installed Debian Wheezy on a RPi 2B, so not aware of the procedure.
FallChallenge
Thu Mar 10, 2016 2:03 am
How to migrate from RPi2 Raspbian jessie to RPi3? I did an
apt-get update && apt-get dist-upgrade
but the RPi3 still doesn't boot! :x
Thu Mar 10, 2016 12:31 pm
You have to update /etc/apt/sources.list and all files in /etc/apt/sources.list.d that have "wheezy" in them. Delete (or rename to .list~) the collabra.list, update raspi.list to
deb http://archive.raspberrypi.org/debian/ jessie main ui
then run sudo apt-get update && sudo apt-get -y dist-upgrade and hope it works.
FallChallenge
Fri Mar 11, 2016 3:01 am
DougieLawson wrote:You have to update /etc/apt/sources.list and all files in /etc/apt/sources.list.d that have "wheezy" in them. Delete (or rename to .list~) the collabra.list, update raspi.list to
It worked!
Thank you very much! :)
PiFreelancer
Tue Jun 28, 2016 4:58 pm
step 1 : put a fresh raspbian in rpi-2
step 2 : do a kernel update with rpi-update
step 3: backup the disk image
This disk image is ready for rpi-3.
Tested well.
HawaiianPi
Wed Jun 29, 2016 1:21 am
PiFreelancer wrote:step 2 : do a kernel update with rpi-update
I thought rpi-update was depreciated and it was done through dist-upgrade now?
rpdom
Wed Jun 29, 2016 4:51 am
In most cases (including this one), yes.
rpi-update should only be used when debugging a specific problem at the request of someone from the RPF, or when there is a known problem with a release and the fixed version is not in the main repository yet. If any instructions say to use it - check the date they were published. If more than 2-3 weeks old they are probably out of date.
bensimmo
Wed Jun 29, 2016 5:37 am
Out of curiosity, if I rpi-update, do you continue to use apt as normal to get updates or are you stuck with using rpi-update from then on?
rpdom
Wed Jun 29, 2016 6:49 am
bensimmo wrote:Out of curiosity, if I rpi-update, do you continue to use apt as normal to get updates or are you stuck with using rpi-update from then on?
You will need to use apt-get to upgrade anything else, but it may revert your kernel and bootcode to an earlier version as apt doesn't know what rpi-update has done.
After a while, the versions that rpi-update installed will be come available, or even superseded by the apt-get version and you will be up to date again.
Wed Jun 29, 2016 7:07 am
It's a one shot kernel replacement. It gets you on the leading edge of the kernel development. Running apt-get after running rpi-update does no harm.
Running rpi-update should only be done when someone who understands your specific problem tells you to run it (possibly as a test of their kernel/firmware changes) to fix something that's broken. Running it daily is dangerous and may leave your system unbootable.
Return to “Raspberry Pi OS”
