Malman35
How to keep the keyboard layout the same!!!
Wed Mar 09, 2016 12:01 pm
I have been VERY frustrated recently because I used to use a Japanese layout keyboard and recently I started using a keyboard with a british layout (I like the look of it better and it fits better on my desk)
Anyhow I changed the keyboard layout using Mouse and Keyboard Settings (it is found in the menu under preferences)
It worked except when I rebooted it switched back to the JP layout! I also changed it in Raspberry pi Configuration (it is found in the menu under preferences) But same thing happened!
I tried
sudo raspi-config
and looked at the keyboard settings there but it was all just different models of Japanese Keyboards. It is like my rpi is got set in its memory that the keyboard is JP layout. How can I change it and keep it changed?
DirkS
Re: How to keep the keyboard layout the same!!!
Wed Mar 09, 2016 12:06 pm
Malman35 wrote:I have been VERY frustrated recently because I used to use a Japanese layout keyboard and recently I started using a keyboard with a british layout (I like the look of it better and it fits better on my desk)
IIRC this was a problem with the first version of the GUI config program and should have been solved in later versions.
Try updating / upgrading.
AFAIK setting it through raspi-config should work fine.
Malman35
Thu Mar 10, 2016 5:16 am
DirkS wrote: IIRC this was a problem with the first version of the GUI config program and should have been solved in later versions.
Okay so I did
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
and after reboot the keyboard stayed to UK layout but only in the GUI. In the command line without the gui started it is still JP layout! How do I fix that? BTW I switched the layout in Mouse and Keyboard Settings and the gui version of Raspberry pi Configuration.
But layout settings in sudo raspi-config seems to only be for different keyboard models (I think they are all JP keyboards)
Malman35
Thu Mar 10, 2016 9:25 am
UGGGG!!!!!! :x :x :x :x :x
IT SWITCHED BACK AGAIN!!! (in the GUI) This is so annoying trying to type only to find out that I have to change it again!!! :x
Why can't it just stay the same!!!! Someone please help me! :oops:
Thu Mar 10, 2016 2:01 pm
What's in your /etc/default/keyboard? My UK version has
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="gb"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
Malman35
Fri Mar 11, 2016 3:02 am
DougieLawson wrote:What's in your /etc/default/keyboard? My UK version has
XKBMODEL="pc105"
XKBLAYOUT="gb"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
Ah ha!
XKBMODEL="pc105"
XKBLAYOUT="jp"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
I switched it to gb like yours was. Many thanks :)
Return to “Raspberry Pi OS”
