Kragmort
VLC
Wed Mar 09, 2016 10:41 am
Witam,
Od 5 dni nie mogę rozgryźć problemu z vlc na raspbianie.
Próbkuję przechwycić mulicast. Jest on nadawany na udp://@239.111.1.1:1234, z komputera o ip 10.111.50.4
RPi ma ip 10.111.50.3 i pinguje nadawcę i na odwrót więc się widzą.
Multicast działa dobrze bo na VLC na innym komputerze (z win 10) odbieram po udp://@239.111.1.1:1234.
pi@raspberrypi:~ $ cvlc udp://@239.111.1.1:1234
VLC media player 2.2.1 Terry Pratchett (Weatherwax) (revision 2.2.1-0-ga425c42)
[01fa63a8] core interface error: no suitable interface module
[01e368f8] core libvlc error: interface "globalhotkeys,none" initialization failed
[01ecf8a8] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[01ecf8a8] core interface error: no suitable interface module
[01e368f8] core libvlc error: interface "dbus,none" initialization failed
[01ecf8a8] dummy interface: using the dummy interface module...
[6fd00998] core access error: cannot join multicast group: No such device
[6fd00998] udp access error: cannot open socket
[6fc00508] core input error: open of `udp://@239.111.1.1:1234' failed
[6fc00508] core input error: Your input can't be opened
[6fc00508] core input error: VLC is unable to open the MRL 'udp://@239.111.1.1:1234'. Check the log for details.
pi@raspberrypi:~ $ cvlc udp://239.111.1.1:1234
[00e5f3b8] core interface error: no suitable interface module
[00cef8f8] core libvlc error: interface "globalhotkeys,none" initialization failed
[00e5f3b8] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00cef8f8] core libvlc error: interface "dbus,none" initialization failed
[00e5f3b8] dummy interface: using the dummy interface module...
[6fc00998] core access error: cannot connect to 239.111.1.1 port 1234: Network is unreachable
[6fc00998] udp access error: cannot open socket
[6fb00508] core input error: open of `udp://239.111.1.1:1234' failed
[6fb00508] core input error: Your input can't be opened
[6fb00508] core input error: VLC is unable to open the MRL 'udp://239.111.1.1:1234'. Check the log for details.
cvlc udp://@10.111.50.4:1234
[00c022f0] core interface error: no suitable interface module
[00a928f8] core libvlc error: interface "globalhotkeys,none" initialization failed
[00c02358] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00c02358] core interface error: no suitable interface module
[00a928f8] core libvlc error: interface "dbus,none" initialization failed
[00c02330] dummy interface: using the dummy interface module...
[6fd00998] core access error: socket bind error: Cannot assign requested address
[6fe00648] core input error: open of `udp://@10.111.50.4:1234' failed
[6fe00648] core input error: Your input can't be opened
[6fe00648] core input error: VLC is unable to open the MRL 'udp://@10.111.50.4:1234'. Check the log for details.
pi@raspberrypi:~ $ cvlc udp://10.111.50.4:1234
[01c873e0] core interface error: no suitable interface module
[01b178f8] core libvlc error: interface "globalhotkeys,none" initialization failed
[01c873e0] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[01b178f8] core libvlc error: interface "dbus,none" initialization failed
[01c873e0] dummy interface: using the dummy interface module...
Możecie mi podpowiedzieć co robię źle? :)
przemof
Re: VLC
Wed Mar 09, 2016 10:00 pm
A VLC lokalnie działa bez prolemu?
Masz uruchomione Xy czy wszystko z konsoli?
Nie wiem czy omxplayer jest w stanie to odtworzyć, ale warto spróbować.
Kragmort
Re: VLC
Thu Mar 10, 2016 8:17 am
Poradziłem sobie sam...
zmienna $DISPLAY się nie zapisała i po restarcie ją wywaliło...
po dopisaniu DISPLAY=:0 poszło
Teraz mi tylko klatkuje, ale to już zabawa z bitrate ;)
Return to “Polski”
