carlox
av output
Tue Mar 08, 2016 12:56 pm
can the signal coming from the av jack be modified from 4:3 to 16:9?
Re: av output
Tue Mar 08, 2016 1:02 pm
carlox wrote:can the signal coming from the av jack be modified from 4:3 to 16:9?
It is Analogue COMPOSITE output and limited to PAL or NTSC 4:3 https://en.wikipedia.org/wiki/Composite_video
RPi 4B 4GB (SSD Boot)..
GTR2Fan
Re: av output
Tue Mar 08, 2016 1:15 pm
Yes. Putting...
sdtv_aspect=3
...in config.txt will do it. Bear in mind that the same resolution will still be used as for 4:3, so anything you display that isn't destined to be displayed at SD resolution in 16:9 will be stretched horizontally. That's just the way it is with all analogue composite I'm afraid.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
Return to “Beginners”
