lmoss30
FAULTY PI3?
Mon Mar 07, 2016 12:36 pm
Hi Guys,
i have just recieved a new PI3 from the pi hut, and noticed a component that looks wrong, C99 is this the case see photo,
will it operate like is or do i need a new board or try to repair it?
Lee
GTR2Fan
Re: FAULTY PI3?
Mon Mar 07, 2016 12:46 pm
In relationship to your photo, C99 should be horizontal (vertical in the small image) and attached to the empty pad just to the right of it (top of it in the small image). As we have no schematics, I can't tell you whether it's safe to operate or will behave normally as it is. I'd send it back unless you're good with a soldering iron and can correct it yourself.
Why does the forum software rotate the image through 90 degrees when it's embedded? Argh!
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
6by9
Re: FAULTY PI3?
Mon Mar 07, 2016 1:16 pm
GTR2Fan wrote:Why does the forum software rotate the image through 90 degrees when it's embedded? Argh!
Being a pedant, it doesn't ;) The orientation field in the JPEG header says to rotate it 90 degrees, but for some reason when rendered as part of an HTML page that is ignored. It's displayed with the rotation if just showing the JPEG.
On the phone it comes down to the effort required to rotate the image during capture vs on render (transpose is often expensive).
Almost all modern renderers abide by the orientation field on displaying a single image - WinXP preview was the last major one I remember not doing so. But there looks to be a quirk in HTML - both Firefox and Chrome don't if part of an HTML page. Looks like this was an active discussion a while back https://bugs.chromium.org/p/chromium/is ... l?id=56845 and linked to https://bugs.webkit.org/show_bug.cgi?id=19688#c20
GTR2Fan
Re: FAULTY PI3?
Mon Mar 07, 2016 1:41 pm
6by9 wrote:On the phone it comes down to the effort required to rotate the image during capture vs on render (transpose is often expensive).
Thanks for the explanation. Excuse me if I don't rotate my 22" monitor through 90° to correct this anomaly. It's bolted to the wall on a 3D-printed VESA mount. :lol:
lmoss30
Re: FAULTY PI3?
Mon Mar 07, 2016 1:48 pm
Managed to remove and solder the device back on so hopefully all will work ok,
maybe one for the RP foundation to monitor if components are missplaced
jdb
Re: FAULTY PI3?
Mon Mar 07, 2016 1:51 pm
Automated optical inspection should make this an impossibility.
Can you post the serial number from /proc/cpuinfo please?
Rockets are loud.
https://astro-pi.org
lmoss30
Re: FAULTY PI3?
Mon Mar 07, 2016 4:03 pm
No problem i will once i get home this evening and get some power on the board,
It seems to be running now so hopefully a little bit of soldering has fixed it.
lmoss30
Re: FAULTY PI3?
Mon Mar 07, 2016 8:42 pm
Hi jdb,
How do I run /proc/cpuinfo, if I type this into command line it says permission denied,
ait
Re: FAULTY PI3?
Mon Mar 07, 2016 8:53 pm
cat /proc/cpuinfo
or
sudo cat /proc/cpuinfo
lmoss30
Re: FAULTY PI3?
Mon Mar 07, 2016 8:57 pm
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2709
Revision : a02082
Serial : 00000000d3795bc5
jdb
Re: FAULTY PI3?
Wed Mar 09, 2016 5:07 pm
Thanks.
Rockets are loud.
