so I'm trying to implement some simple video player using JavaFX.
The idea is to download .mp4 videos, store them on sd card, and then play on demand.
As you can see, nothing special.
And it works flawlessly on my laptop.
But as you can imagine, it doesn't work on Raspberry PI (2 model B).
First time I tried to run my JAR I got an error that main class can't be loaded.
I found out that JavaFX is not part of newer embedded versions of JDK8.
So I in order to overcome this issue I downloaded and set up :
- JDK 8u73 for ARM
- OpenJFX 8u40 for armv6hf
Both of these were the latest versions I could find.
So now I can "start" my application but, when the app tries to use FX Media components (player, view, etc.) in order to play Video, I get the following problem :
Java HotSpot(TM) Client VM warning: You have loaded library /home/pi/java/jdk1.8.0_73/jre/lib/arm/libjfxmedia.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
Exception in Application start method
Exception in Application stop method
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:389)
at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:328)
at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:767)
Caused by: java.lang.RuntimeException: Exception in Application start method
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:917)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$152(LauncherImpl.java:182)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.UnsatisfiedLinkError: /home/pi/java/jdk1.8.0_73/jre/lib/arm/libjfxmedia.so: /home/pi/java/jdk1.8.0_73/jre/lib/arm/libjfxmedia.so: wrong ELF class: ELFCLASS64 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1821)
at java.lang.Runtime.load0(Runtime.java:809)
at java.lang.System.load(System.java:1086)
at com.sun.glass.utils.NativeLibLoader.loadLibraryFullPath(NativeLibLoader.java:201)
at com.sun.glass.utils.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:94)
at com.sun.glass.utils.NativeLibLoader.loadLibrary(NativeLibLoader.java:39)
at com.sun.media.jfxmediaimpl.NativeMediaManager.lambda$new$5(NativeMediaManager.java:113)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.media.jfxmediaimpl.NativeMediaManager.<init>(NativeMediaManager.java:104)
at com.sun.media.jfxmediaimpl.NativeMediaManager$NativeMediaManagerInitializer.<clinit>(NativeMediaManager.java:75)
at com.sun.media.jfxmediaimpl.NativeMediaManager.getDefaultInstance(NativeMediaManager.java:87)
at com.sun.media.jfxmedia.MediaManager.canPlayContentType(MediaManager.java:64)
at com.sun.media.jfxmedia.locator.Locator.init(Locator.java:431)
at javafx.scene.media.Media.<init>(Media.java:399)
at domain.model.view.GalleryVideo.<init>(GalleryVideo.java:13)
at domain.GalleryContentProvider.lambda$loadItems$0(GalleryContentProvider.java:78)
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1374)
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:580)
at domain.GalleryContentProvider.loadItems(GalleryContentProvider.java:68)
at domain.GalleryContentProvider.initialize(GalleryContentProvider.java:57)
at Main.start(Main.java:75)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$159(LauncherImpl.java:863)
at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$172(PlatformImpl.java:326)
at com.sun.javafx.application.PlatformImpl.lambda$null$170(PlatformImpl.java:295)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$171(PlatformImpl.java:294)
at com.sun.glass.ui.monocle.RunnableProcessor.runLoop(RunnableProcessor.java:92)
at com.sun.glass.ui.monocle.RunnableProcessor.run(RunnableProcessor.java:51)
... 1 more
Exception running application Main
Has anyone seen this error?
What can I do to fix it?
Thanks in advance!
Best regards,
Hrvoje
