Fidelius
How to disable the Pi3's WLAN & Bluetooth ?
Fri Mar 04, 2016 9:24 am
When on 29th February 2016 Mr. Upton made the nice Pi3 anouncement, in the posts below the announcement, a user asked if the Wifi and Bluetooth features of the Pi3 could be disabled. Mrs. Upton kindly answered:
Liz Upton wrote:You can turn Bluetooth and WiFi off – we’ll make sure there’s an easy interface for you to do that with in our next update.
Can we turn-off WLAN & Bluetooth already now with some simple means, until the easy interface comes?
In the Pi3 Q&A forum thread somebody mentioned some Linux modules to black-list, but is this enough hardware-wise and what exact steps would be necessary? (For those not being experts with hardware and Linux kernel modules.)
Thanks!
HopmanUK
Re: How to disable the Pi3's WLAN & Bluetooth ?
Fri Mar 04, 2016 1:58 pm
I've been trying to find the same information..
I believe it may be possible to alter the kernel to be able to put it in airplane mode permanently, but have not had a chance to try it yet...
# put into airplane mode
rfkill.default_state=0
#stop airplane mode button from doing anything
rfkill.master_switch_mode=0
The only other thing I can think of is to disable the loading of the drivers for now:
/etc/modprobe.d/raspi-blacklist.conf
#wifi
blacklist brcmfmac
blacklist brcmutil
#bt
blacklist btbcm
blacklist hci_uart
I may be wrong on these, but I think we need some input from people in the know.
Rich
denghauser
Fri Mar 18, 2016 8:12 pm
Thanks a lot. The blacklist worked perfect.
Fidelius
Sat Mar 19, 2016 7:36 am
Yes, thanks for these lines!
HopmanUK wrote:/etc/modprobe.d/raspi-blacklist.conf
#wifi
blacklist brcmfmac
blacklist brcmutil
#bt
blacklist btbcm
blacklist hci_uart
Will do that.
Then how do I find out if it worked? Is there some LED or other means to see if the Wifi and Bluetooth hardware is active? (Like one some laptops where there's some hot keys with small LEDs).
Out of interest (and not having activated your blacklist yet), when I "lsmod" my kernel loaded modules, I see the "brcmfmac" and "brcmutil" modules loaded, but not the "btbcm" and "hci_uart" one. Is this normal? (With current Raspbian)
Whiznot
Mon Apr 04, 2016 12:04 am
I thought disabling wifi and bluetooth might lower temperatures and boost performance so I created the raspi-blacklist.conf file and rebooted. Wifi was disabled but the temperature monitor went from 53 to 67. I don't understand why I had a 14 degree rise but after removing raspi-blacklist.conf and rebooting the temp monitor went back to 53.
jahboater
Mon Apr 04, 2016 9:47 am
Whiznot wrote:I thought disabling wifi and bluetooth might lower temperatures and boost performance so I created the raspi-blacklist.conf file and rebooted. Wifi was disabled but the temperature monitor went from 53 to 67. I don't understand why I had a 14 degree rise but after removing raspi-blacklist.conf and rebooting the temp monitor went back to 53.
I saw no change in temperature at all. Are you sure there were no other changes?
Whiznot
Tue Apr 05, 2016 4:23 pm
It works now. I'm not sure what went wrong before. I had the wifi plugin in the system tray before the first attempt that caused the temperature rise. I restored a system backup and removed the wifi plugin before the second attempt that worked. Disabling wifi and bluetooth seems to have decreased temperature by one or two degrees.
bfesser
Thu Nov 24, 2016 11:18 pm
Fidelius wrote:When on 29th February 2016 Mr. Upton made the nice Pi3 anouncement, in the posts below the announcement, a user asked if the Wifi and Bluetooth features of the Pi3 could be disabled. Mrs. Upton kindly answered:
Any word on if/when this will be added to raspi-config and whether or not it saves power?
tweak42
Fri Nov 25, 2016 8:58 am
Not sure if these answer your question.
https://github.com/RPi-Distro/raspi-config/issues/15
http://raspberrypi.stackexchange.com/qu ... nt-setting
olaffit
Tue Jan 31, 2017 2:55 pm
you can simply turn wifi and BT off in the GUI. At the top right.
This option should really go into raspi-config
kwacka
Mon Apr 24, 2017 5:54 pm
I agree the ability to turn off wifi should be part of raspi-config, but will this also enable USB wi-fi devices?
Might blacklisting be the preferred method?
hommar
Mon Apr 24, 2017 7:44 pm
for disable onboard WiFi and BT on Pi3 add to config.txt
dtoverlay=pi3-disable-wifi
dtoverlay=pi3-disable-bt
ronny_b
Tue Apr 25, 2017 1:54 am
I am running Raspbian with Pixel, and there two icons in the upper right of the taskbar, one for WiFi and one for Bluetooth. Clicking on either will bring up a menu. The first item
on both menus is a "clickable" entry to turn off the respective service.
It's bedtime in Misouri - good night everyone.
Ron
daharris
Tue May 23, 2017 5:34 pm
hommar wrote:for disable onboard WiFi and BT on Pi3 add to config.txt
How would you use this method to disable the ethernet?
pcmanbob
Tue May 23, 2017 7:18 pm
Hi.
just do
sudo nano /boot/config.txt
and add those two lines to the bottom of the file then save and reboot.
like this.
# For more options and information see
# http://rpf.io/configtxtreadme
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
gpu_mem=16
# turn wifi and bluetooth off
rbphilip
Sun Feb 18, 2018 12:26 pm
the /boot/config.txt edits work, but so to shell commands.
sudo ifconfig wlan0 down
graysky
Sat Nov 09, 2019 12:41 pm
#wifi
blacklist brcmfmac
blacklist brcmutil
#bt
blacklist btbcm
blacklist hci_uart
With recent kernel version is seems bluetooth is still loading. After some exploring, I found the following is needed to stop:
% cat /etc/modprobe.d/blacklist.conf
# ref: https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=138610
# bluetooth
blacklist hci_uart
blacklist btbcm
blacklist btintel
blacklist rfcom
blacklist btqca
blacklist btsdio
blacklist bluetooth
# wifi
blacklist brcmfmac
blacklist brcmutil
