My pi 2 has the power go on and off if the case is moved in the slightest way. Is my power source bad? It's a Vilros kit I got from Amazon. Do I need to get a better power supply?
Is the power supply inside the case? Obviously whatever is causing the problem has to in some way be connected to the movement and I wonder if it's something other than the wall wart part of a power supply, given it is so far away from the actual pi. Could it be the connector, either the power supply side or the pi side? I'd try just slightly touching that and see if it restarts. Of course doing all this isn't really that great for the electronics, so I'd want to find out what the deal was without too much messing around.lynchd wrote:My pi 2 has the power go on and off if the case is moved in the slightest way. Is my power source bad? Do I need to get a better power supply?
lynchd wrote:My pi 2 has the power go on and off if the case is moved in the slightest way. Is my power source bad? It's a Vilros kit I got from Amazon. Do I need to get a better power supply?
