QBall1977
RPi3 and rpi-update - A warning.
Thu Mar 03, 2016 10:18 pm
Dear All,
Just my thoughts, I've been using all Pi's for a while. But mostly a Pi B2 as mini setup for my daughter that I've now come to reply upon as I found it ran Citrix better than the laptop my employer supplied for me!
However just upgraded to a Pi3. Was going through the basic setup and install (made a backup of my card, but putting it straight in the Pi3 it seemed a little buggy unstable), best do a clean install.
Was running fine until I installed and ran 'rpi-update' command. This resulted in a broken install, the Pi starts to boot, scrolls through the usual (that should take less than 30 seconds, which is impressive!) but now hangs once initialising usb devices, I thought it may have been my USB speaker, but removed it, rebooted, the same thing. Hangs on 0z: (1 GPs behind) then Task dump for CPU2). I would recommend not using rpi-update (at least not for a while!)
Just a heads up.
Kind regards
Mark.
Pi2 / Pi3 - Raspbian Fresh Install March 16. :geek:
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
GTR2Fan
Re: RPi3 and rpi-update - A warning.
Thu Mar 03, 2016 10:21 pm
The use of rpi-update has always been discouraged unless you want to try new experimental features with the accompanying risks that entails. It's not a part of the standard update process and never has been.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
jellowiggler
Fri Mar 04, 2016 6:02 am
I need a way to fix this.
My new Pi3 now won't boot. It just keeps cycling in the same manner.
How do I fix it? :oops:
jellowiggler
Fri Mar 04, 2016 8:06 am
Just for the newbs like me.
Format the SD card.
Download NOOBs.
Start over.
Easy as that. Super awesome! Back in action!
Don't run rip-update unless you want the very very bleeding edge.
So probably not on brand new hardware that's only been around for a few days. :-)
QBall1977
Fri Mar 04, 2016 9:36 am
The good thing is, a reflash of a clean install a swift boot and off I went again. Took less than an hour to reinstall the majority of apps and files. One single massive apt-get command, 800MB later, it just works!
Still easier than installing a copy of windows. Although installing Citrix again proved a faff. But Chromium for the win! Again solid advice from this forum as always! :D
Sat Mar 05, 2016 8:57 am
jellowiggler wrote:I need a way to fix this.
If you can boot to a command line with network connectivity then sudo apt-get install --reinstall raspberrypi-bootloader will undo the damage done by unadvised use of rpi-update.
I'll do your homework for you for a suitable fee.
rurwin
Sat Mar 05, 2016 9:02 am
If you've got a spare SD card you could write a new image to that and then copy the contents of the boot partition of the new card to the old card.
Neutrosider
Thu Mar 17, 2016 11:59 am
I had serious network-problems on my PI3 before (it just stopped working at some point). Then i used rpi-update to update firmwares, and now everything works just fine
