I want to lower the profile of my LCD screen to my Pi zero when it comes so last night I managed to remove the Female header pin on my 4inch LCD. Very slowly and carefully but I still ripped one out. Unfortunately it was a ground according to the gpio. 10th pin upper row.
I noticed also that there are 3 other ground pins in that section used by the LCD. Is there some way to turn off that pin and reroute it to another pin?
Can I do without that pin?
Here's a pic showing the damaged eyelet.....................
See pics on later posts
The other eyes I removed the pin using a soldering iron so the inner sleeves are fine. I used a small heated safety pin to open the other eyelet up. So the other eyelets should be fine.
Any body have any oppinions?
