gbru316
Parsing serial data from arduino
Tue Mar 01, 2016 3:53 am
I'm trying to read serial data and use it in some logic statements.
The plan is to play audio on RPi when a button is pushed (connected to arduino DIO pins), but at the moment I'm just trying to manipulate the serial data... baby steps :lol:
I'm able to read the data with the RPi (print the serial data received) but when I try to analyze it, I get nothing.
while 1:
     x=ser.readline(2)
     print x
     if x == 25:
          print("pushed")
Shell window displays 25 when the button is pushed, but "pushed" does not display. Conversely, when I set the statement to !=, it says "pushed." I'm guessing it has something to do with data type (binary vs ascii, string vs int, etc)? Anyway, what's the easiest way to implement this?
stderr
Re: Parsing serial data from arduino
Tue Mar 01, 2016 4:48 am
gbru316 wrote:
     if x == 25:
          print("pushed")
If you say
if x == "25":
doesn't it work?
PeterO
Tue Mar 01, 2016 8:12 am
stderr wrote: If you say
if x == "25":
doesn't it work?
or the other way round should work as well
if int(x) == 25:
Also might need to watch for problems caused by any white space that may surround the digits in the string.
PeterO
gbru316
Tue Mar 01, 2016 1:25 pm
Found the solution: had to use '25' instead of 25 or "25."
liudr
Tue Mar 01, 2016 10:06 pm
I think your problem is that you used Serial.print instead of Serial.write in your Arduino code. You should have posted that code.
Arduino data loggers, user interface, printed circuit board designer since 2009, RPI 3B 2B 2B Zero Jessie, assembly/C/C++/java/python programmer since the 80's
Return to “Beginners”
