timmoore46
Editing /boot/config.txt
Tue Aug 07, 2012 7:11 am
I log in to Raspbian and 'startx'
wake up leafpad and load /boot/config.txt
change it and.....
it won't save cos I've not got the permissions.
How to I get to be the SU / admin/ Sudo here?
feeling credibly dumb here !
:roll: :roll: :roll: :roll:
An embarrassed,
Tim
Jim JKla
Re: Editing /boot/config.txt
Tue Aug 07, 2012 7:18 am
put your SD in a windows card reader config.txt is in the only part of the SD you can access fron windows ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
rurwin
Tue Aug 07, 2012 7:20 am
The quickest way is probably to start a terminal and type:
sudo leafpad /boot/config.txt
The more streamlined approach would be to create a shortcut icon or menu entry that started "gksudo leafpad", but I don't know how to do that in LXDE. (Someone will probably pop up and tell us.)
timmoore46
Tue Aug 07, 2012 7:28 am
Many thanks both !
I'll try the Bash approach first !
:D :D :D :D
Tim
Update:- it worked !
bredman
Tue Aug 07, 2012 8:02 am
For full instructions to edit this file, see the wiki
http://elinux.org/R-Pi_ConfigurationFile
redhawk
Tue Aug 07, 2012 8:55 am
Since the boot partition is fat32 you only have to stick the SD Card into a memory card and open config.txt in Windows or Mac or Linux or any other OS that supports fat32.
Richard S.
Neda behrouzi
Fri Aug 08, 2014 3:15 am
Hi Everyone,
I purchased a License VC-1, received the key, insert the SD into my computer ( windows), found the config.txt file.
But I do not know how to insert the :decode_WVC1=0x....... There is already a default mentioning : decode_WVC1=0x00000.
I do not know whether I have to edit this existing default or add another command ( which I do not know how?). I am not professional in these things. would anyone please help me by describing in detail what exactly I have to do?
Thanks.
A1i2T3R
Fri Aug 08, 2014 9:36 am
in the terminal type:
sudo nano /boot/config.txt
you can do this with ssh if you want to copy and paste.
Enthusiastic pi user, with a hoby for modding everyday objects and using the pi as the brain!
drgeoff
Fri Aug 08, 2014 9:40 am
Neda behrouzi wrote:Hi Everyone,
Thanks.
Replace the 0x00000 number with your licence key. And if there is a '#' at the start of that line, delete the '#'.
Return to “Beginners”
